hi up 4 sale is my 2000 subaru rx
full show car custom orange with gold pearl with cwest bodykit
carbon fibre bonnett
full purple swade interior
with leather seats and custom sound setup with indash kenwood dvd player
2pioneer 10 inch subwoofers with pioneer and jvc amplifiers
and 19 inch dolce dc12 chrome rims
only dwnside 2 the car itz missing the front lip and has a small dent in behind the numberplate from someone reversing into me
other then dat the car is mechanicaly a1 always looked after reason for sellin is the car ayent real practical for my job
this car perfect 4 p platers
can contact me on 0422646767 chris az im not on here much
$11000 4 sale or swap for something of interest
located sydney west mt druitt
https://www.sau.com.au/forums/topic/325635-rx-show-car-4-sale-or-swap/
yah mate got any picturez specz??
yer its n/a 46000 ks 1st aus owner sound system,hsd tt adjustable coilovers,20" lenso eminence wheels,no body damage whatsoever,2.5" catback exhaust, only downside is its trip tronic,i have original suspension setup, spitfire coilpacks, rego till decmber 30th.
sorry about the pics.
yah lookz alright were boutz u located
:nyaanyaa:
would u be interested in a nissan 200sx s14a 1998 model, turbo 16 pound 189 rwk dino proven, to ten inch subs , 19 inch rims, body kit , only reason i want to get rid of it is because of licence issues , only down fall it has is its an auto, ?
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
