Basically been right through the car.
Had a small amount of rust in the front of the chassis.
That was cutout and plated with the whole underneath of the car proofcoated before the car was complied and licensed.
All new suspension with Koni shocks and king springs.
Selby swaybars
Bigger turbo with front mount intercooler and Autronic computer.
Retrimmed interior with WRX seats
Heaps of other things that I've forgotten over the last 2 years :)
  • 4 months later...
WOW, what a difference a tuner makes.
After the new turbo and autronic fitting dramas I was never that happy with the performance of the car.
Something was just not right but the tuner assured me it was as good as it could be.
It was running out of injectors and needed upgrading so that limited the power to 220rwhp.
The power was OK but the delivery was woefull.
Problem was that changing from first to second near the redline resulted in some lag until the revs built up again.
It was not really pleasant to drive that way and made it difficult to use in the tight circuit as per the above youtube video.
So the car has been sitting in my Son in laws workshop since June as I have no space left at home (too many toys).
We changed the injectors and returned the car to the same tuning workshop (the tuner had loked the Autronic so I had to go back (another story))
Anyway the well renowned tuner only worked contract for the workshop and is unreliable. He started working on the tune encountered a problem then dissappeared for weeks at a time.
i asked the workshop to get their new tuner to look at it instead of waiting so he went right through the car and found a number of problems that the other guy had overlooked. First off the turbo actuator was not operating correctly , there was an issue with the timing causing the missfire that the other tuner walked away from. To the new tuners credit he rang Autronic over east and sought some advise and fixed the problem the supposed Autronic expert tuner couldn't.
Anyway the results are amazing. Not only was there a power increase ,when changing into second this beast tries to shred the tyres :O:):D
This car is so torquey now by comparision. Felt like a new car when I drove it back to my Son in Laws workshop.
He will service the car and we'll do a few other jobs over the next 2 weeks until his new house is finished and the DR gets a permenant home at his place. I can then house the DR or GTR at his place so I can get to drive which one I feel like.
So to summarise
Tuner 1 =220rwhp
Tuner 2 =288rwhp :P
The tuner got the car to post 320rwhp but backed it off at my request as he recommends an actuator change to a lower psi rating to control the boost better.
The engine is stock internally
I've fitted a KKR380 turbo and PI-1 intercooler.
http://www.streettuned.com.au/Forced-Induc...S/prod_462.html
http://www.otomoto.com.au/kkr/intercoolers/index.html
plus a Autronic SMC computer and keeping boost to 17psi.
The 288hp is just a number so not sure what you'll get on another dyno.
Main thing for me was going from 220 to 288hp on the same dyno
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
