Just Bought An R33 Skyline Gts25t - Pics, Specs And Help Needed :)
yeh dude its andrew, thought it was you things been pretty cruisy how bout your self
yeh good mate,
guys noticed when there cars been driven around for a while and i park i can hear a ticking sound coming from the motor - im guessing its the lifters - how bad a problem is this? does it mean the engine is probably a little tired? its meant to have a geniuine 68kms according to autoworx
could be - the last owner did service it at Kmart Tyre and Auto - god knows what sh*t they put in it.
Tune + Service on Friday so il let the guys at AllStar Garage know all the issues and see what happens
Edited by s13-steve
That sounds about right for the engine mods you have? You don't have an aftermarket ECU, if you got a full aftermarket ECU and got rid of that SAFC Neo, upped the boost a bit, then you would probably get a bit closer to 280.
Doubt it.. 260rwhp give or take, is pretty much on the money. Try a different dyno and you might get 280 :)
the dyno sheet the previous owner gave me from Xspeed was 278rwhp so i was expecting something around that...
ah well 260rwhp is 193rwkw so not to bad i guess, just doesnt feel any faster then my CA18 which had 196rwhp
Yeh, thought it would be pretty much correct. Does a SAFC Neo prevent boost cuts so you can run higher boost though? Surely with a stand-alone aftermarket ECU you could run a bit more timing and boost, bring it a bit closer to 280?
The SAFC should allow you to raise your afm cut (it's not boost cut damnit! :)) as you're bending the afm signals, so the cut threshold would be proportionatly higher.
A full aftermarket ECU would allow you to wind some timing in to it but whether you would see top end gains with the 25 turbo already so close to its' limits would remain to be seen. Generally, being able to adjust timing helps with getting bigger turbos on boost (i.e. improve midrange).
Like I said, another dyno might give you a reading of 280rwhp but they are just tuning tools, not comparison tools.
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
