  • Replies 91
Does anyone have a list (or know where to find one) of servos that sell E85 in little old Adelaide?
Preferably at the pump for convenience.
Want to get a tune to see what the 3076 will make on it...
OG Speed shop maybe...
https://www.sau.com.au/forums/topic/326099-e85-in-adelaide/#findComment-5309975
tapleys hill servo at seaton.. the united sel it there for 99.99 c/l!
Damn... other side of town from both home and work... lol.
Oh well worth it to see how it goes. Just get a tune and swap to it when I feel like going down there i suppose. :verymad:
Thanks all!
https://www.sau.com.au/forums/topic/326099-e85-in-adelaide/#findComment-5310298
does anyone know what sort of power increase you would get on say a gt30 or hi flow on e85???
Well mine is making 273rwkw on 18psi (3076 .82 IW) on PULP98 on a fairly easy tune.
Simon from Morpowa thinks E85 should bump it up to around 310rwkw.
He said the most he's seen a 3076 on E85 is i think 320 whereas a bunch of people on here have been seeing 330-340+ with similar mods so i think the Morpowa dyno might read on the low side...?
https://www.sau.com.au/forums/topic/326099-e85-in-adelaide/#findComment-5310368
awesome thats similiar specs to my turbo, what ecu u running?
https://www.sau.com.au/forums/topic/326099-e85-in-adelaide/#findComment-5310394
here is my 3076 dyno on e85. 334rwkw on 22psi.
Case in point why i think Morpowa's dyno might be low reading. Simon said he hadn't seen a 3076 over 280rwkw on PULP but there's plenty around on the board hitting 300rwkw with the same setup as mine...
https://www.sau.com.au/forums/topic/326099-e85-in-adelaide/#findComment-5310419
how much do these go for?
Lots... :verymad:
Cost me like $2500 installed (from memory) and $1200 to tune but Simon and the guys at Jap Motorsport rave about them - the main reason was if i get defected it can be tuned well enough to engineer the car and get it back on the road unlike a Power FC.
Got tons of other features to play with later on down the track if the car becomes track oriented (since i'll prolly never see the money i've sunk into it) like traction control, launch control blah blah.
Edited by gwilkinson34
https://www.sau.com.au/forums/topic/326099-e85-in-adelaide/#findComment-5310434
So all much of a muchness to most 3076 setups - difference in output must be down to happy or sad dynos hehe.
Well i've had my HKS3037 .68 E85 (Same core as the 3076) on 5 different Dyno's around Adelaide(Mainline and DD) and power has ranged from 348-359rwkw at 23psi.
https://www.sau.com.au/forums/topic/326099-e85-in-adelaide/#findComment-5310619
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
