Hey all
Need to sell the following , Was building a four door r32 as a tough sreeter / drift toy but have just been informed my work is sending me to our overseas office for 6-8 months with the possibilty of staying over there longer.
ENGINE RB24 ( BOTTOM END )
BOTTOM END IS BRAND NEW
SPEEDLAB CUSTOM RB24 ( CUSTOM MACHINED R34 GTR CRANK )
GRUB SCREWED CRANK
EAGLE RODS
TOMEI PISTONS
ARP RACE SERIES STUDS
TOMEI RINGS
PISTONS HAVE BEEN TEFLON COATED
FRESH LINE BORE AND HONE
ACL RACE SERIES MAIN AND ROD BEARINGS
CUSTOM SUMP BAFFLES
CUSTOM 9L SUMP
N1 OIL PUMP
THIS BOTTOM END HAS BEEN MADE TO STAND BIG HP AND BIG RPM. ONLY TOP QUALITY PARTS FROM JAPAN, USED AND THE BEST MACHINING HAS BEEN DONE.
THIS BOTTOM END HAS COST ME CLOSE TO $10K
WILLING TO SELL FOR $7500.00
ENGINE ( HEAD )
FULL RACE PORTING
JUN 280 – 10.8mm LIFT ( BIG ) INLET AND EXHAUST CAMS
JJR ADJUSTABLE CAM GEARS
TOMEI SPRINGS
TOMEI GUIDES
GREDDY TIMING BELT
THIS HEAD IS TO SUIT ABOVE BOTTOM END, HAS BEEN FULL PORTED WITH BIG CAMS, LIFTERS, TOMEI SHIMS, TOMEI SPRINGS, GUIDES, WILL ALSO THROW A BRAND NEW GREDDY TIMING BELT IN.
THIS HEAD HAS HAD OVER $6K SPENT ON IT IN MACHINING AND PARTS FROM JAPAN.
WILLING TO SELL FOR $4,000.00
ENGINE ( PERFORMANCE / FUN STUFF )
GENUINE HKS 25/30 ( DONE 2000KM SINCE NEW ) $1400.00
XSPEED JAPAN STAINLESS LOWMOUNT EXHAUST MANIFOLD $ 500.00
HKS DUMP ( SERIES 2 WITH LARGER GATE OUTLET ) $ 350.00
MICROTEC LTX12'S WITH FULL WIRING $ 800.00
587cc SIEMANS INJECTORS BRAND NEW $ 600.00
TOP SECRET FUEL REG IN TOP SECRET GOLD $ 250.00
OS GIKEN TWIN PLATE, USED FOR 3000KM IN GREAT CONDITION $1000.00 SPEEDLAB DRAG COOLER ( 600 X 320 X 115 ) BIG! $ 700.00
R32 FOUR DOOR ROLLING SHELL WITH PLENTY OF PARTS, PRITTY MUCH EVERYTHING EXCEPT ENGINE, GEARBOX. CAR CAN BE REGISTED IN SA, HAVE REGO PAPERS FOR THIS
1990 SILVER R32 FOUR DOOR
INTERIOUR IS IN DECENT CONDITION FOR AGE
EXTERIOUR IS IN OK CONDITION FOR AGE
PARTS ON CAR AS FOLLOWS
CEFIRO CROSS MEMBER ( SITS THE ENGINE 30mm LOWER FOR BETTER GRAVITY )
KAAZ 2 WAY DIFF CENTRE
GTR DIFF CASING ( BETTER COOLING AND MORE OIL )
SOLID REAR FRAME BUSHES
SOILD DIFF MOUNT
CUSCO COMP COIL OVERS
CUSCO FRONT AND REAR STRUT BARS
CUSCO BRAKE MASTER STOPPER
CUSCO REAR UPPER ADJUSTABLE ARMS
ARC CASTER ARMS
EXTRA LOCK STEERING KNUCKLES AND ARMS ( FORGOT BRAND BUT THERE JAP )
R32 GTR CALIPERS AND DISCS ALL ROUND
TOP SECRET BRAKE PADS
D2 HYDROLIC HAND BRAKE AND CUSTOM LINES
BOSCH 044
CUSTOM SWIRL POT IN BOOT
N1 HEAD LIGHTS
MOMO STEERING WHEEL
HKS BOOST GAUGE
N1 BONNET LIP
EXHAUST MANUAL CONTROL VALVE
3 INCH EXHAUST
THERE IS OVER $10k IN AFTERMARKET PARTS ON THIS CAR NOT INCLUDING THE CAR ITSELF. THIS ROLLING SHELL IS A GREAT STREET / DRIFT STARTER WITH ALOT OF POTENTIAL.
WILLING TO SELL FOR $7000.00
Or
If someone whans everything as a complete package im willing to sell for $17K for everything !!!
OFFERS WILL BE LOOKED AT !
PICTURES WILL BE UP THIS WEEKEND.
I know your probably not considering this at the moments but if/when you are Id be interested in 2 way and the knuckles. Just send me a PM if it ever gets to that stage.
Any pictures or more info on the head? Who did the work, flow figures, std valves etc? Was the combustion chamber opened up to suit the larger bore of the RB24 or will it still work on a 20?
Hey all
ROY - Head work was done by SPEED LAB & RHEMAC ENGINEERING here in Adelaide, Its had alot of porting on both inlet / exhaust , it has tomei valves or JUN valves ( ill have to get back on that ), Yes the head will work fine on a RB20. As people know standard rb20 heads are very restrictive !
BL4CK32 - I will keep you in mind if i split those items
cheers
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
