hi im new to your forum im from the uk have had my car for 3 years now and have got a wierd problem
the car idles fine when standing still fine when below 5mph and fine when the speed sencor is unconected so this elemenates any mecanical elements, pipes off, spilts ect ect so this is something one of the ecus is telling somthing in the engine bay to do the thing is i dont know where to go next any ideas? i have tryed unpluging a few things in the engine bay with the car up on jacks idleing high in second gear to no avail am at a bit of a lossbonk.gif
dan
https://www.sau.com.au/forums/topic/326547-hi-idle-when-the-car-is-above-5mph/
Cant make exact sense of the situation you are trying to describe but i think it is 1 of 2 possible things.
1 -and this is normal and not anything to worry about-
R33 skylines will idle higher than the base 650rpm idle speed until the car does in fact come to a dead stop. (possibly to generate enough power in the hydraulic systems to work everything such as brakes n power steering even if you are n neutral and the engine is only using idle speed but you are coasting at 100kmph). So yes, it uses the speed sensor to tell the engine to idle higher (usually between 900-1100rpm) until the car reaches a dead stop.
Also- R33's will idle high due to autochoke remaining on until the the first time you come to a complete stop after the car has reached desired operating temp. Even if this is 30 minutes driving later that you first come to a stop. So again the ecu will monitor the speed sensor and only tell the autochoke to turn off at a time that the car has come to a complete stop.
2-this is a problem, but solved by simple maintenence
the idle/choke mechanism is sticking and isnt working right because it has become dirty due to the age of these cars and can cause a variety of interesting idling characteristics from high idle to overly low idle. Iv had it before that my car would idle at over 1600rpm on autochoke and the autochoke would not turn itself off. I would have to turn the car off once it was warm and then restart it- and because the car was warm it would not engage the autochoke and so it would now idle at the normal rpm.
if it is this you need to have the mechanism removed and cleaned out.
good luck.
good luck.
Are you referring to the AAC valve?
sorry been at work all day just got it the idle is around 1250 to 1400have cleaned the acc valve and reset my car never yoused to do this because on my way home there is a long down hill to my house and i always coast to my house so the tubby can cool down so this problem has just started i have had the car for three years now
is the cold start valve under the inlet plenum above the oil water cooler? because if it is i disconected this with the electrical plug and still the same thing happens have also disconected the acc valve and the same happens again is there any other way that the ecu can control the idle?
that not super high, is it really a problem? how often do u just coast with ur clutch depressed anyways, as long as its not idling that high when stationary (warm) i wouldn't worry about it.
but if ur set on trying to locate it, to me it sounds like the acc valve, just coz its clean doesn't mean its not faulty
good luck buddy
good luck buddy
i have disconected the acc electricaly and had the car up on blocks and leaft it idle and put it in 2nd and the revs still rose up so there must be anouther way that the ecu controls idle might get a consolt cable and plug a laptop in and see wat happens there are a lot of cars in the uk with this problem i just want to find out wat it is as it bugs me lol
Pin 44 is the neutral signal. The ECU knows when the car is not in neutral.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
