I hit the search button,
but it seemed to bring up only automatic gearboxes using J-Matic or something the rather? Please can i have some suggestion as to what i should use for a 6spd manual oil and also diff oil? Thanks in advanced.
https://www.sau.com.au/forums/topic/326751-transmission-diff-oils/
Whatever you use, make sure you've got a GL4 oil for your gearbox and a GL5 for the diff. Personally I like Redline MT90 as it stands up to a lot of track days, but can be a bit thick in Winter. MTL is good for street-use. Didn't rate the Nulon stuff and currently running Castrol Syntrans, which isn't too bad but I haven't been using it for very long.
I have a 1.5-way diff so I use Motul competition oil, 75w130 weight or something.
I have change my Manual box oil recently. You can try Motul Gear 300. It can be used for both box. I was recommended Royal Purple for my gearbox, by this autobarn guy, as they ran out of Motul. I can say not totally happy with the purple. It's works ok after a few km during early morning cold start, but during the 1st set of traffic lights I pull up. Always have difficulty put it into 1st gear, sometimes 2nd gear too. After the oil has warm up, then It do feels very smooth. I have yet to change my Diff oil, so I guess you can try some other and we'll see how. The purple does seems to be much thicker than the old oil I took out. Quite a lot of metal filing can be seen from my old oil, but maybe the oil got so old that it has thin out. It's recommended by nissan to putting 75W-80 for gearbox and 80W-90 for Diff. The Royal Purple and Motul are both 75W-90.
Thanks for the fast reply guys,
i changed the motor oil as soon as i got the car few weeks ago but never even thought of doing diff and trans till i spoke with a fellow SAUer last friday. I drive maybe 10kms per day if that, pretty clean run with barely any stop/start but id rather be safe then sorry :)
Now regardless if your a Nulon fan or not,
this is a good guide to use: http://www.datateck.com.au/lube/NulonAus/default.asp
Just specify car, nissan, then i went for 350z and it lists in categories ie motor, trans etc which oil you should use.
Edited by TUFF_350
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
