Hey all ive got a 1996 4 door R33 GTS-T auto.i have put forged pistons and metal head gaskets in and a highflow turbo with all the other normal mods 3inch, pod, fmic, ebc and a stage 3 shift kit put in. I am looking at getting a full replacement ecu and new injectors. The car is making 300hp atm with a SAFC2. My car is poor on fuel even driving off boost. I was just wondering what workshop is best for my kind of car being an auto ,which management would you use ? thanx
https://www.sau.com.au/forums/topic/326849-r33-auto-tuning/
im from down south i got the shift kit done at South West Automatic Transmissions bunbury. i reckon it was 1 of the best things ive done to the car so far .be good to see how it gose with a good ecu and tuned.
Can you PM me details please? This is the first mob I've heard of that do them in WA! Hopefully they can do the tiptronic boxes..
https://www.sau.com.au/forums/topic/326849-r33-auto-tuning/#findComment-5327271
  • 2 months later...
any ecu will work
the auto transmission is not controlled by the ecu like on the r34
you will lose timing retard on shift changes , shifting will be more abrupt . but if your getting a shift kit anyway it won't really mater
hi.. um is that true? the auto is not controlled by ecu????????
an wat you mean will loose retard timing on shifts?? is that all the ecu really does??
coz i swapd ecu's one day an it wouldnt shift to good at full noise..
was like it lost the electronic shift at full throttle....
so a shift kit will fix??
cheers
https://www.sau.com.au/forums/topic/326849-r33-auto-tuning/#findComment-5481201
cheers
In R33's the TCM and the ECU are separate, R34 they are in the same unit.
When you use a non-auto ECU it doesn't know to receive signals from the TCM to cut timing when the gearbox wants to shift gears.
This is pretty much what happened with the Haltech in my wagon, it would flare horribly on the 1-2 change and not go in at high rpm unless I lifted the throttle or bounced the limiter.
Got a shift kit installed and it is phenomally better, it doesn't care that the ECU isn't cutting timing, it just GTF in there.
https://www.sau.com.au/forums/topic/326849-r33-auto-tuning/#findComment-5481807
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
