The 255/40 and 285/35 are within a .5" difference which should be fine for the AWD.
I'm not AWD but i am running those same tire specs on my car. Wheels are 19x10.5 +43 all around with a 5mm spacer up front to clear the arms.
  • Like 1
After adding a 5mm spacer: 245/40-19x9.5 +35
So what have I learned.... I think the following is a perfect set-up for the V36 skyline rwd sedan;
Front: 245 or 255/40-19x9.5 +35 (possibly a 245/40-19x9.0 +35)
Rear: 285/35-19x10.5 +45
Edited by R377
Here is a sedan w/370 z wheels. Specs on the 370z wheels are:
front - 19x9, +47 offset
rear - 19x10, +30 offset
He is running a 20mm spacer on the front so the offset is essentially a 27mm.
The rear tires stick out because they have 295/40 tires. 275/35 would be perfect.
370z wheels are made by Rays and are 6-7lbs lighter than coupe wheels made by Enkei
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Girls can roll too.  Natalie was previously rolling on Vossen VVS-CV7s in Matte Graphite Machined in 20x9 20x10.5 +32/45 on 255/35/20 285/30/20. g37 sedan Vossen v36 skyline sedan
Natalie changed her setup to 20x10.5 +45 all around with Vossen VVS-CV7s in Silver Polished wrapped in 255/30/20 Nitto tires. I have a 5mm Akata Spacer front and back to prevent rubbing against the control arm in the front while giving some poke to the back
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
