Hay guys,
I guess im wondering if anyone else has shit radio reception and what can be done to improve it.. Its generally pretty fine around the city but has some areas where its completely crap and as soon as you get past around the 50km mark from the city the radio becomes non existant.
When i bought the car it had a jap radio it it which only had a very narrow band and it was really bad so i put my aussie cd player in and that made it marginally better but its still crap.
Is anyone else having this same problem and what have you done about it?
Stu
https://www.sau.com.au/forums/topic/327311-terrible-radio-reception/
Hay guys,
Stu
just make sure you connected power to the antenna amplifiers when you installed new head unit, from memory it is the wire linked to the antenna plug behind the head unit.
Does it need positive 12v power to that plug? that would probably explain why my radio is so shit!!
  • 4 weeks later...
nothing to buy, factors amplifiers are hidden away behind rear door, your power wire will be there.
I finally deciced to try this power amplifier thing and i cant seem to find the wire. At the back of the loom where the aerial plugs into the back of the stereo i have to plugs, one smaller than the other. The bigger one plugs into the back of the stereo. I follow that back and it goes to a black socket type join, i follow it back further and it goes to a white plug with one wire coming from it, that wire goes straight back into the main loom. Im pretty clueless when it comes to car electrics. Can u please help?
Thanks
Stuart
Ill send you some pics either this arvo or tomorrow.
While on the top of Radio Reception, I've still got the factory m35 A/V set-up but what I'm wondering is what will I pick-up in the way of Digital Radio with the Hawk Ranger III once installed?
I will mostly be in the Blacktown / Granville regions.
OK, blue wire is my antenna power from my head unit (so amps on come on ONLY when i select radio). This goes to the white wire (bottom arrow), which in turn feeds 12V to yellow black wire (top arrow) and on to amps. You may have had your wires cut, so may not have original block like mine.
pretty sure it is cabin temperature sensor, plugs into dash, left and below of steering wheel where the sensor is, the job of this pipe is to draw air past the sensor when the air con is on. If you dont have climate control, mighten have this sensor.
AFAIK it has climate control. The A/C unit is the same as RS. It has the temp sensor mounted behind the front bar but only has dash sensor on pass. side of dash.
The part the pipe fits to in the pic is not there.
Thanks all sorted. Its still not 100% but what can you expect when you live on a mountain. Its alot better than its ever been. At least it doesnt drop out all together. Thank you very much
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
