Hey guys time to clear the shed! All the parts are from a 1997 R33 GTST Series II unless stated.
Instrument cluster (with ALSD) 155xxx kms - $80
Dash assembly - $100
Front and rear seats - $150
Set of front and rear seat belts - $50
Clutch (with master), brake and accelerator pedals (RAZO pedals) - $60
Brake booster and master cylinder (with ABS) - $50
Set of front and rear door trims (without switches) - $100
Glove box assembly - $30
Steering wheel with airbag (leather has wear) - $100
LHF passenger airbag assembly - $100
Rear boot with spoiler (has one crack underneath spoiler) - $50
Type-M factory side skirts (RH has minor split on edge) - $100
LHF guard (in black) - $50, LHF Nismo smoked indicator lens - $20
Heater core - $30
Stock exhaust system - $50
S13 Silvia accelerator cable for front facing plenum (good fit) - $30
More to be added soon.
PM for details. Parts located in Adelaide
Edited by DRFT33
https://www.sau.com.au/forums/topic/327771-garage-cleanout/
Heater core - $30
hey mate, any pics of the LHF guard? has the panel been resprayed before? any damage to paint or panel??
https://www.sau.com.au/forums/topic/327771-garage-cleanout/#findComment-5331204
hey i am in need of the razo pedal set :P and also the clutch master cylinder :D please let me know how much $ posted to the usa!
also i am in need of the boot lock with the nissan logo if you have that!
thanks
https://www.sau.com.au/forums/topic/327771-garage-cleanout/#findComment-5339002
  • 3 weeks later...
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
