Hi all. After spending hours on here I finally decided to sign up. Recently purchased a series one R33 GTS manual. Last car was a 03' Mazda RX8 6 speed which was involved in an unfortunate incident. :whistling: Look forward to hearing from you all in the future as I am looking to shortly upgrade my suspension, convert to 5 stud and a brake upgrade, and eventually a RB25DE+T conversion.
https://www.sau.com.au/forums/topic/328133-noob-from-vic/
sorry mate i dont mean to be a rude f**ker but how do u go from a $35000 to a $5000 N/A 33 ???? did u not have insurance or something
Yeah, I get that alot. Lol. Had comprehensive on it, and finance. :yes: Repairable write off. I only paid $28k for the car with 53,000km on it, but when I pranged it I only got $22k back after depreciation, tow fees etc. Didn't want to get back into the debt cycle again so decided to go with something a bit more reasonable and cheaper to maintain. The things we do when young and dumb...
https://www.sau.com.au/forums/topic/328133-noob-from-vic/#findComment-5338328
smart decision.
dont bother upgrading your n/a to turbo i assume your on p's and thts why u hve suggested this but u can buy a turbo 33 for the price of a n/a 33 so just sell up and re buy when the time comes wasting time and money converting an n/a
https://www.sau.com.au/forums/topic/328133-noob-from-vic/#findComment-5338571
smart decision.
More than aware of that. I'm on P's for another 8 months, I'm not sure what I want to do in regards to an upgrade. Motor swap, DE+T or just buy another car. Re-evaluate when the times comes as i'd prefer a R34 turbo. I like tinkering with my cars, so the 8' was boring in that sense, the 33 is the kind of car I can modify however I want without feeling guilty or selling a kidney. The DE+T idea is more a of a project and a bit of fun instead of just taking the easy way out. Lol.
https://www.sau.com.au/forums/topic/328133-noob-from-vic/#findComment-5338697
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
