Cornerstone CM 200 cable modem for sale.
I have used this with my optus cable for the last year and do not require it anymore. It is able to download upto 1MB per second from a fast connection. Has usb and ethernet connections.
$200
Or make me a reasonable offer coz otherwise it will end up collecting dust.
https://www.sau.com.au/forums/topic/32865-cable-modem/
  • 1 month later...
  • 1 month later...
  • 1 month later...
