R32 Gtr Seats Recovered In Leather, Gtr Grille
R32 GTR Front seats recovered with "reborn automotive leather" from proseat.com.au $800
Plus also have:
R32 GTR Front Grille (Genuine in Gunmetal Grey) $140
RB25DET Standard Exhaust Manifold $40
R32 GTSt Half Shafts $50 (for both)
R32 GTSt viscous LSD centre $20
S15 3.7:1 Diff Crown and Pinion $50
Payment pending for the GTR Grille...
Also have genuine R32 floor mats...
Rear mats $100 - they are the thicker carpet style, with metal "Skyline" Tag. Awesome condition for age with almost no sun fade on the centre mat
Front mats $50 - the carpet on these is the thiner style, with plastic Skyline Logo. Drivers side is fairly worn, but probably still better condition than most, passengers side is good.
whats the condition of the seats under the leather covers?
The seats were in excellent condition, however some upholstery glue was used to help stick the new material onto the seats. So I imagine they wouldn't look too good if you wanted to pull the covers off and use the original seats underneath.
 Share
    • Does this count as a time trial as well? I got all gold in the master super licence (1 lap time trial) and received a McLaren MP4/4 for my trouble.  If anyone else has done this, did you ride the wall right around the first long right hander at Lake Louise snow track to get gold? I couldn't do it any other way... best I could do without riding the was was within 2 tenths of the gold time.
    • I definitely get the low power, sporty car to drive to smash gears but not be doing eleventy million miles an hour! It makes all the normal drives fun!   Rev match tune sounds like the funs! I didn't know the NC had a DBW throttle!   As for me, still have the Skyline, it still has the Barra in it. It's been pushed to the side of the workshop at the moment. Pretty much waiting on me finishing the wiring, and dropping new fuel lines in. Got myself an ACDC Tig end of last year so been teaching myself TIG welding to build a few things for the Skyline. The missus wrote off her GTB liberty at the end of last year, and got it back on salvage rights stupid cheap. It's also still registered, so will mean easier for me to take to the track already done most of the panel damage, just playing "clear the workshop" to make space to pull the motor and box out, fix some oil leaks, replace the clutch, and replace a few minor broken things.  Also got a Lathe at the start of the year, which is adding to the annoyance of no space, which is another reason I'm trying to build things to get more space, to get the Lathe back in a final home for it. It's a BIG lathe, can turn a 355mm diameter, and 1metre between centres... Got it at a steal! So between it and the TIG and old MIG welder, I'll be fabbing some fun little shit up But we've had a lot of shit stuff happening at home, so it's slow going getting things done. But one step at a time!
    • I love Catalunya.  Got a 1:54.632. The AMG is a hoot.
    • I hadn't got that far, my main worry was the connection to the actual calipers themselves. I'm just using new (ish) stock brake lines in the stock setup. I've just had a stud welded to the knuckle that is a little lower than the original stud (so my knuckles have two studs each side) to not have it be stretched so far in previous BBK setups, so the "block" (in the second picture) mounts a little lower for me and I hope I don't need to change anything. I may have even changed the connection to the calipers in the past and have since forgotten I did that. I may not have. Guess how I'm gonna find out. Source: hopium
    • It's more so I'm using the 1x piece line from HEL that goes from the body to the caliper. There's no middle block/mount like the HFM ones or the GKtech ones. There are certain angles/suspension compression where the line actually slightly contacts the ARB. Below of how mine sit (not my photo): How I want it:
