Hi Guys,
Hoping some of the brake Gurus can help me out here.
I am about to purchase calipers for my GTR rear brake upgrade and have been looking at the Ap 5000+ series of calipers. Now the only suitable caliper for the rear (4 x 38mm pistons) accepts 295mm rotor maximum. I would like to run 343 or a min of 330mm.
Now the 7600 series of caliper (used in the Ap Formula kits and the like) has virtually the same dimensions/pad number etc as the 5000+ and also suggests that 295mm is the biggest rotor it can accept. If this is the case how are people running larger rotors. Is it another part number being ordered or are they just running the larger disc.
I have printed out the technical drawings from the website and cant find anything to help me.
Could someone please shed some light on this before i order becausr i dont want to end up with calipers that can only run this smaller disc.
I have also put this question to AP but have no response as yet.
The links are as follows:
5000+
http://www.apracing.com/calipers/products....2F%3E_2680_2678
7600 series
http://www.apracing.com/info/products.asp?...2F%3E_2761_2569
Feedback would be greatly appreciated. BTW i am going to run the 6 piston 5000+ caliper with 375 x 36mm rotor on the front with AP pedal box.
Thanks in advance
Matt
https://www.sau.com.au/forums/topic/329304-ap-rear-caliper-selection/
Not sure about part numbers etc but have a look at the AP rears on here:
http://www.nismo.com.au/pricelists/pricelist_gtrbrakes.htm
330x24mm single piece rotors with drum.
I went with the alcon front and rears - pretty well balanced with the standard master cyl. The cp5555's are nice in being able to run the 36mm thick rotor, but I dont think I will ever need it!
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
