Hi Guys,
Just left overs from my r32 that I just sold. All Parts are for R32 unless stated otherwise. Need this stuff gone asap, all prices negotiable, but don’t be rediculas everythings cheap already. PM or call me 0400200997.
- Cusco rear strut brace - $100
- Nismo front Strut Brace - $100
- 3” xfocre dump and front pipe 1 piece mild steel - $100
- 3” Cat back, mild steel, with 1 muffler, and twin 2.5” diff back straight pipes - $250
- 3” Diff back cannon 5” tip jasma approved - $80
- GKtech sump/bash guard alloy - $150
- Grex/Gready 16 row oil cooler, with relocation kit, braided lines, missing fittings - $500
- Splitfire coilpacks rb20 less than year old - $250
- Nistune ECU in stock manual ecu - $250
- Bosh VL alternator with modified harness for r32 (way better then Hitachi crap) less than 6 months old - $250
- FMIC piping kit, alloy - $100
- Stock BOV - $30
- Top secret GTR Front Grill, fibre glass, white - $100
- GTR N1 genuine front bar, needs work, cable stitched in parts, can be fixed or perfect drift bar - $250
- Stock Cat with 3” pipe welded through, much better then punched out - $50
Call or PM 0400 200 997
Cheers Paul.
https://www.sau.com.au/forums/topic/329348-garage-sale-cheap-melbourne/
what fittings are missing off the oil cooler?
All of them, I have the braided line, but missing the fittings, includeds relocator and adaptor. Quality items made in USA, not china.
Oil Cooler sold...Following still for sale...
- Stock BOV - $30
  • 4 weeks later...
  • 3 weeks later...
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
