Hi Guys,
Just left overs from my r32 that I just sold. All Parts are for R32 unless stated otherwise. Need this stuff gone asap, all prices negotiable, but don’t be rediculas everythings cheap already. PM or call me 0400200997.
- Cusco rear strut brace - $100
- Nismo front Strut Brace - $100
- 3” xfocre dump and front pipe 1 piece mild steel - $100
- 3” Cat back, mild steel, with 1 muffler, and twin 2.5” diff back straight pipes - $250
- 3” Diff back cannon 5” tip jasma approved - $80
- GKtech sump/bash guard alloy - $150
- Grex/Gready 16 row oil cooler, with relocation kit, braided lines, missing fittings - $500
- Splitfire coilpacks rb20 less than year old - $250
- Nistune ECU in stock manual ecu - $250
- Bosh VL alternator with modified harness for r32 (way better then Hitachi crap) less than 6 months old - $250
- FMIC piping kit, alloy - $100
- Stock BOV - $30
- Top secret GTR Front Grill, fibre glass, white - $100
- GTR N1 genuine front bar, needs work, cable stitched in parts, can be fixed or perfect drift bar - $250
- Stock Cat with 3” pipe welded through, much better then punched out - $50
Call or PM 0400 200 997
Cheers Paul.
https://www.sau.com.au/forums/topic/329348-garage-sale-cheap-melbourne/
what fittings are missing off the oil cooler?
All of them, I have the braided line, but missing the fittings, includeds relocator and adaptor. Quality items made in USA, not china.
Oil Cooler sold...Following still for sale...
- Stock BOV - $30
  • 4 weeks later...
  • 3 weeks later...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
