Hi Guys,
Just left overs from my r32 that I just sold. All Parts are for R32 unless stated otherwise. Need this stuff gone asap, all prices negotiable, but don’t be rediculas everythings cheap already. PM or call me 0400200997.
- Cusco rear strut brace - $100
- Nismo front Strut Brace - $100
- 3” xfocre dump and front pipe 1 piece mild steel - $100
- 3” Cat back, mild steel, with 1 muffler, and twin 2.5” diff back straight pipes - $250
- 3” Diff back cannon 5” tip jasma approved - $80
- GKtech sump/bash guard alloy - $150
- Grex/Gready 16 row oil cooler, with relocation kit, braided lines, missing fittings - $500
- Splitfire coilpacks rb20 less than year old - $250
- Nistune ECU in stock manual ecu - $250
- Bosh VL alternator with modified harness for r32 (way better then Hitachi crap) less than 6 months old - $250
- FMIC piping kit, alloy - $100
- Stock BOV - $30
- Top secret GTR Front Grill, fibre glass, white - $100
- GTR N1 genuine front bar, needs work, cable stitched in parts, can be fixed or perfect drift bar - $250
- Stock Cat with 3” pipe welded through, much better then punched out - $50
Call or PM 0400 200 997
Cheers Paul.
https://www.sau.com.au/forums/topic/329348-garage-sale-cheap-melbourne/
what fittings are missing off the oil cooler?
All of them, I have the braided line, but missing the fittings, includeds relocator and adaptor. Quality items made in USA, not china.
Oil Cooler sold...Following still for sale...
- Stock BOV - $30
  • 4 weeks later...
  • 3 weeks later...
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
