Hey guys its time for me to sell my daily which has served me well for the last year. I have a new car and need this gone. It has the basic bolt-ons and some goodies, however requires a bit of TLC. I think it would make a solid slider with a locker and few things attended to, or just change clutch/balljoint and ready to go as a daily again. Specs are below.
Model: 1989 Nissan Skyline GTS-t 4 door factory manual turbo
Colour: Grey/Silver
KMS: ~156km
Mods: FMIC, pod filter, 3" dump/front into 3" stainless jap cat-back, Cusco coilovers (front left bush split and needs replacing), Nardi 330mm steering wheel, front drivers & passenger R32 GT-R seats (drivers bolster worn), trust grex gearknob, c's short shifter and some oldschool jap 17's. Also has Mongoose M80 alarm system.
Things in need of attention:
-A/C doesn't work but I will supply a replacement compressor.
-The body is rough in areas and has a tiny bit of rust in corner of rear windscreen.
-Power steering has a leak.
-Front-left coilover needs the top bush replaced and is knocking.
-Standard clutch is tired and needs replacement.
-Rego has expired around a week ago. I can pay the registration at the buyer's expense.
-I will also be taking out the stereo so BYO head unit and speakers.
The car is on currently on ebay but I'd rather a straight out inspection and sale instead of time wasters that auctions attract!! Please see link for pics
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...=STRK:MESELX:IT
SAU PRICE $4750.00... NEGOTIABLE within reason!!
Please contact me on 0424 141 211 for any enquiries or to arrange an inspection. Located SE Suburbs Melbourne.
Cheers,
Michael
Edited by discern
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
