Hi, I have two sets of GTC wheels for sale. email [email protected]
Location: Melbourne. prefer pickup but can arrange freight at buyers cost.
1st set
18x10 +15 all round, FACE-2 type, carbon center caps, wheel nuts,
will clear big brembo's and 6pot alcon brakes. RAYS don't make these offsets with big caliper clearance anymore. $3200. no offers. (pics below)
2nd set
18x9 +29, 18x10 +38, carbon center caps, FACE-2 low disk type,
two wheels have some gutter rash and slight dent on the outer rim edge (see pics attached). wheels are not buckled. $2500.
(pics below, wheels are a bit dirty, need to clean with warm soapy water)
  • Replies 69
sorry to jump in on ur thread but i have no idea how these havnt sold yet its been ages.
big bump gl with the sale
also where did u get ur spoiler from that is on ur r34
thanks
julz
price drop for GTC's 18x10, 18x9 - $2350 (pics in first post, above)
price for the other set 18x10 +15 all round is firm at $3200 (pic below)
pickup in melbourne preferred, or can organise freight to east cost for $70-$80.
hi mate i was after set of these wheels 18x10, 18x9
i well offer you 1800 with no disrespect becuase the tyre point is selling 19x9.5 and 10.5 for 2800 with tyres used as well thanks
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
