Drivers side.
On the front windscreen.
The black shaft.
If you can locate the gearbox. Look for the transfer case. The thing protruding out from the drivers side of the gear box is the transfer case. There is a driveshaft the protrudes from the transfer case to the fron diff to drive the front wheels.
Im not sure if this has been explained in this thread how the ATTESSA system works. ATTESSA is the name of the driveline system.
It is the same as the GTR driveline.
Its not AWD. Its not RWD.
Under normal circumstances 100% of the power is sent to the rear wheels to drive the car. Making it a RWD car.
The system uses ABS wheel speed sensors, G sensors, steering input and actual speed sensors to assess whether any of the four wheels are spinnning or the car is sliding.
Once these inputs senses there is something going fishy. The ECU works out how much of the power needs to be sent to the front wheels to keep you out of a tree. From there, hydrolically operated clutch packs engauge in the transer case, which turns the drive shaft which drives the front diff and hence the half shafts and then the wheels. Making the car AWD.
Once the system has kept you out of a tree, the clutch packs disengauge and the car becomes RWD again.
Hope this helps
https://www.sau.com.au/forums/topic/329610-gts-4/page/2/#findComment-5362927
No, your car will shit itself and the transfer case will turn into glitter and a troll will jump out of your gearbox and kick you in the nuts.
Seriously, your car has ~100kw at the wheels, you have no chance in hell, in the wet it will skid, like any car above 40kw, but you will definitely not produce smoke, however you may be able to produce some noise, something like LLOOOLLLLLL coming from your tyres because you tried to "smoke them"
https://www.sau.com.au/forums/topic/329610-gts-4/page/2/#findComment-5364899
My AU falcon makes heaps of smoke, surely it doesn't have much more than 100kw atw.
Anyway, burnouts are shit, all they do is ruin your tires and there's no skill so it doesn't look cool. Once you get your car RWD, you should attempt roundabout drifts in peak hour.
Joke, but I'm pretty sure an n/a skyline would be able to smoke the tires, it's just pointless.
https://www.sau.com.au/forums/topic/329610-gts-4/page/2/#findComment-5365356
im not going to get into the discussion of what silly car can do burnouts, but just keep this in mind:
Au falcon- 4ltr
157kW @ 4900 rpm.
357Nm @ 3000 rpm.
1437kgs
33 GTS4 - 2.5ltr
139.75kw @ 6400rpm
230.46nm @ 4800rpm
1440kgs
thats curb weight for both... the au has alot more down low torque due to much larger capacity motor.... specs do not work out well for the skyline.....
sources: http://www.cars-directory.net/specs/nissan...e/1995_1/21676/
http://www.trueblueford.com/AU_FalconS_Specifications.htm
http://en.wikipedia.org/wiki/Ford_AU_Falcon
so no, waste of time, thread is going to go to rubbish if we continue talking about this crap.
https://www.sau.com.au/forums/topic/329610-gts-4/page/2/#findComment-5365627
thanks mate that pic is alot of help:)
if i remove this would i be able to smoke my back wheels?
*faceplam* you shouldn't be around ANY car or public roads.....
If I read correctly you came on here asking for help to smoke your tires..... :P
https://www.sau.com.au/forums/topic/329610-gts-4/page/2/#findComment-5366850
here's how you can smoke your tyres without removing the drive shaft
1: remove tyres from car
2: cut up tyres with a jigsaw
3: put pieces of tyre in a blender
4: roll tyre crumbs in tally-ho paper
5: smoke tyres as much as you like
I would like to do that, but combine it with candle wax mmmmmm smells good
https://www.sau.com.au/forums/topic/329610-gts-4/page/2/#findComment-5368180
front propeller shaft is the correcet term :D driveshaft is what the CV's are attached too
theres no point in doing it becuse oil will come out the transfer case and running it without oil wont be good, you will need to plug the hole up with a special tool just for that
https://www.sau.com.au/forums/topic/329610-gts-4/page/2/#findComment-5373725
Theres only 2 sensible ways of disengaging the 4WD..
1. What Dave said, remove air evacuation connector (drivers side, lower right instrument panel) and depress the brake 5 times within 10 seconds after placing the ignition switch to ON position. At the same time the 4WD warning light will flash twice a second to indicate it is in RWD mode. To return it to 4WD mode u place the ignition switch to OFF and reconnect the air evacuation connector. I've tried it and it works but never left it in RWD mode for long at all just in case it causes some kind of damage.
2. Remove front drive shaft.
But don't know what would happen to the drive line components if you left it in RWD mode for an extended period of time. Possibly could do some damage to something in the long run? anybody knows?
https://www.sau.com.au/forums/topic/329610-gts-4/page/2/#findComment-5382159
you wouldnt have anypictures of that air evacuation connector would oyu?
https://www.sau.com.au/forums/topic/329610-gts-4/page/2/#findComment-5398076
  • 1 month later...
You could try a torque split controller?
apprently there for the attessa system, and gives you control of the awd settings or
you can go rear wheel..
why would you buy a gts-4 if you wanna "smoke your back wheels"?
https://www.sau.com.au/forums/topic/329610-gts-4/page/2/#findComment-5488263
Sorry mate thats wrong, it can only turn a car from awd to rwd for the r32 gts4's as they have electronic controllers, whereas the r33's have hydrological ones. All it does for 33 gts4s is controls how much goes from the back to the front, what ratio: 50/50 60/40 70/30 ...etc..
if its on 0 and you manage to slip the rear wheels it will start at the factory 5% to the front... if you keep skidding it will put more power to the front until the geforces go back to normal.
https://www.sau.com.au/forums/topic/329610-gts-4/page/2/#findComment-5488353
lol this whole thread reads like some schoolkid's fantasy or some kind of BS.
It's a heavy, N/A 2.5 litre. You're not going to get anyone around here giving you advice on how to do skids, in what is possibly one of the worst cars for it. Sell it for a profit and buy a VN. You'll be happier in the end.
https://www.sau.com.au/forums/topic/329610-gts-4/page/2/#findComment-5488501
my bad ;)
you think there worth it on a gts-4 33?
https://www.sau.com.au/forums/topic/329610-gts-4/page/2/#findComment-5488542
my bad :D
I have one... makes a huge difference and I have tested with tyres down to string on a wet skid pan, with 230rwkw.... theres still skidding, but about 60-70% less....
Was the first mod I did and really happy with it....
You feel everything alot more, steering wheel goes firmer, response feels better, its a useful mod.
https://www.sau.com.au/forums/topic/329610-gts-4/page/2/#findComment-5489155
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
