Item: Nismo LM GT4 rims x 4 (5 x 114.3) - Fronts are 7.5 inch wide (+40 offset) rears are 8.5 inches wide (+43 offset).
Age: Unknown
Condition: Good - a couple of minor gutter scrapes and one wheel has had a repair (done professionally by Wheel Revolution). Has tyres but they are not roadworthy.
Price: $2500 o.n.o.
Reason for sale: Sold my 34
To Fit: Had them on my R34 GTT with 3mm spacers on front (to clear the calipers) so should fit cars with similar offset
Location: Brisbane. Can organise freight at buyers expense.
Contact: Please pm me or call/sms 0404 089 369
Comments: Tyres on fronts are Toyo Tranpath 225/40ZR18 with 15% tread, rears are Nankang 235/40R18 Ultra Sport NSII with 10% tread and have camber wear.
Pics will be up soon (once I work out how to post them :happy:). Otherwise send me a pm and I'll email some to you. If you check the link below there is a pic of them on my 34.
https://www.sau.com.au/forums/topic/329616-nismo-lm-gt4-18-inch-bronze-rims/
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
