benm: i was under the impression that in a RWD car you wanna run soft rears to put the weight on the rear tyres when launching so you can get away quick enough.... stiff suspension would just spin and cost time.... can someone elaborate and tell me whether i'm on the right track or not?... (no pun intended)....
HOLY S**T!!!!!
what the cortina run? is it 6 or 8 cylinder? (im guessing it's not a 4)....
Newly built. Twin turbo V8 (not sure what ci)
Did one shakedown pass.... 1.2 sec 60 footer, backed off and coasted over the line for a 10 second pass...
His rear muffler was sparking on the ground when changing into 4th gear doing around 110mph. You can't tell me that is healthy for a quick pass (not that im a pro at drag racing or anything).
I absolutely love the car tho :( :( :(:)
If it's too soft, the car squats and the IRS changes angle and the tyre contact patch is less, therefore less traction.
But too hard in suspension the tyre (sidewall) needs to be the suspension and take the motion, if you don't have enough sidewall, this will lead to wheelspin.
It is an artform, i don't know much about it but i'm trying.
Benny i've showed you a few times how to launch a powerful IRS car before a few times haven't I?
I absolutely love the car tho :(:) :) :)
Yeh soft rear susp can help traction off the line, basically inertia moves weight over the rear axle, which increases the friction available.
But i think Bens right, surely there must be such a thing as too soft, as my friend commented, 1-2 & 2-3rd it almost bounces the rear axle off the track :) Shame his wastegate isnt venting to atmosphere, add the aural delight of the T51 high pitch scream
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
