Hey mate im after the whole setup for rear 5 stud conversion.
Im from s.a aswell so i can come have a look.
send me your num so i can come down sometime.
cheers
PM me.
is Nismo Dash + CF vented bonnet to fit R32 GTR? or GTST only? Can you please pm me pics if they are still available.
Thanks
speedo is sold. unsure of what latch is needed for the bonnet, it came off a GTS-t but not sure which latch it used.
is that greddy cooler for a gtr??? if so how much posted to 4211 nerang qld
yes, GTR.
postage will be around $50 at a guess. let me know if ur serious and ill get a quote.
wat brand are the s13 castor rods?and do u still have the 32 gtr passenger seat for sale?pm me as im not on here alot
unsure of castor rod brand, they are sold pending payment. GTR seat is still fs.
still got the intercooler and piping? got a pic and how much would shipping to canada be
i do, not sure how much, but id expect it to be a lot lol
probably be cheaper to buy something locally
Hey mate,
Just wondering if you had the gtr cooler still and if you could send me a couple of photos.
Also located in SA, but Victor Harbor :)
Cheers, Rob
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
