do you have dash plasics,the plastic panel that runs under dash, plastic gear stick surround, plastic trim from drivers arm rest, plastic cup from passenger arm rest and the left and right door handle plastic inserts?
everything I need is in this attachment.
https://www.sau.com.au/forums/topic/33010-r33-parts/#findComment-662726
ok guys so so sorry i havent replyed earlier as use asked
prices
dash $500
head 800
front quater panels left n right 200 each
ill have pictures of them all within a day so sorry again
after i have posted the pics basically just give us a buzz pricas can be negotiated so yeah.. cheers
https://www.sau.com.au/forums/topic/33010-r33-parts/#findComment-665477
