  • Replies 51
The speeds etc look right.
Mine is the same.
On 12.5psi I made 152rwkw on RPM's Dyno then 15psi made 164rwkw (turbo runs out of puff). Turbo's differe and give you a rough idea. You could be making +10-15rwkw.
Jay95R33.
If you are getting boost drop no matter what you bump it up to you will always drop to that same psi up top. Get your self an RB20t wastegate that is a little stronger (10-11psi stock). UNLESS you get your self a good EBC that learn's the boost curve and can adjust the solanoids on the fly to make it hold boost. I.e Blitz SBC-ID & AVCR.
You don't have to remove the turbo to replace the actuator.
Why buy an aftermarket actuator?? All you have to do is install a coupla washers onto the mounting points of the stock actuator and this automatically puts more pressure onto the wastegate flap!
I put 2 washers on each, and this raised the boost by 3psi from stock! Good value for 20c compared to a few hundred $$$. Less spiking from the bleeder too, since it now had to bleed substatially less boost to get the same result.
Cool - thanks Joel. I never thought of that !! So the RB20 turbo's have the same actuator (but diff spring rates)?
Busky2k - I'm not a big fan of dodging up the actuator. Seen a few people play with them like bending it and putting extra springs on, but they are never the same.
J
  • 1 year later...
SDEWY5,
That would be because you are not mechanically inclined.
The washer, elongated holes or adjustable rods work fine.
In fact the washer or the rest would be more reliable, at least you know its not going to jam or bugger up.
Whats with the 2004 post revival?? haha :D
  • 2 years later...
  • 4 weeks later...
is there any reason why this is in the forced induction quick ref guide, there is no real help here unless i missed something, some one had a flat spot and does not know how he fixed it, what help is that?
there is also a lot of reference to a dyno graph that is no longer here.
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
