  • Replies 51
The speeds etc look right.
Mine is the same.
On 12.5psi I made 152rwkw on RPM's Dyno then 15psi made 164rwkw (turbo runs out of puff). Turbo's differe and give you a rough idea. You could be making +10-15rwkw.
Jay95R33.
If you are getting boost drop no matter what you bump it up to you will always drop to that same psi up top. Get your self an RB20t wastegate that is a little stronger (10-11psi stock). UNLESS you get your self a good EBC that learn's the boost curve and can adjust the solanoids on the fly to make it hold boost. I.e Blitz SBC-ID & AVCR.
You don't have to remove the turbo to replace the actuator.
Why buy an aftermarket actuator?? All you have to do is install a coupla washers onto the mounting points of the stock actuator and this automatically puts more pressure onto the wastegate flap!
I put 2 washers on each, and this raised the boost by 3psi from stock! Good value for 20c compared to a few hundred $$$. Less spiking from the bleeder too, since it now had to bleed substatially less boost to get the same result.
Cool - thanks Joel. I never thought of that !! So the RB20 turbo's have the same actuator (but diff spring rates)?
Busky2k - I'm not a big fan of dodging up the actuator. Seen a few people play with them like bending it and putting extra springs on, but they are never the same.
J
  • 1 year later...
SDEWY5,
That would be because you are not mechanically inclined.
The washer, elongated holes or adjustable rods work fine.
In fact the washer or the rest would be more reliable, at least you know its not going to jam or bugger up.
Whats with the 2004 post revival?? haha :D
  • 2 years later...
  • 4 weeks later...
is there any reason why this is in the forced induction quick ref guide, there is no real help here unless i missed something, some one had a flat spot and does not know how he fixed it, what help is that?
there is also a lot of reference to a dyno graph that is no longer here.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
