There actually quite good man. I brought an r32 which these came on it. The car has been sitting in a shed for 8 Years! collecting dust. hence why the wheels dont look good. its got a heap of dirt packed on it.
Will give it a clean 2moz and post another pic for you mate.
What are these rims worth new?
And last but not least. The only reason i asked is because on the inside of the rim there is ASAHI TEC on the rim
Heres a pic of it.
Cheers Guys
Asahi Tec (Factory Subaru, Suzuki wheels) is an OEM supplier of wheels in Japan. the same as Enkei (Honda) and others. Basically they make the wheels with the agreement that whatever company can buy them and rebadge them. Asahi Tec is a good company. I'm not saying the wheels are bad, just that the are not worth very much.
cool thanks man, just came into the skyline scene as i have had vl's and know everything from top to bottom on rb30's and vl's.
been signed up here for a while but didn't really use it. but now i have an excuse to use it more ;)
im keeping the skyline so might aswell keep the wheels i got with it which are these. oh and there 17 x 7's multi fit.
thanks for the info champ!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
