Selling an ARC turn flow intercooler for a GTST R33 Series 1 or 2.
Will not need to cut into body work so you won't risk defects to the car. You only need to shave off abit of the air con fan housing. Bolts on directly
I am selling the intercooler used but in great condition. No bent fins.
PRICE: $700
Payment: COD, Can post but postage to be paid by buyer. Brisbane / Gold Coast buyers, I can deliver...
Throw me an offer.
Edited by k3vv
hey does it come with the bolts n stuff to bolt onto the car
To bolt onto the car, there are 3 points to attach:
1 uses the nut that holds the bonet latch. Undo and attach!!!
2 more at the bottom of the intercooler. Its just a 10 mm nut that will be provided. All the connecting pieces that holds the pipes together are provided.
Buy, plug and play baby
Any more details / pics of this?
I've been looking at fitting a Blitz LM FMIC to my car at the moment, and there's no way it's gonna clear the aircon fan housing and I don't feel real comfortable cutting into it.
oh yea shit bein that easy to install sounds so temptin but im tryin to get the rest of my exhaust then ill b lookin at somethin like this im tryin to reach the 200kw mark
I am quite confident that this FMIC will be able to carry that amount of power you are trying to achieve, and even more........
JRM Any more details / pics of this?
JRM: I think no matter how you go, you will need to shave off a bit of the housing. What I did to my car was just shave off part of the 'wing' that is sticking out of the fan housing. It won't throw the fan out of whack or anything. The more important bit is that the reo bar does not need much modification or cutting into.... What sort of pics do you want?
To the both of you, check out the link. I have done this myself too and its dead easy.
http://www.skylinesaustralia.com/forums/R3...tml&hl=fmic
PS. check the first pic below item no. 8 and how the bit of air con fan housing needs to be shaved. Thats all in it....
The FMIC I am selling is exactly the same
Wow. Just wow, okay - I just learnt something.
The R33 fan is *totally* different to the R34 fan. The R34 fan the middle part has a plug and sticks *way* out from the housing - like maybe a good inch out. That's what the FMIC I'm trying to fit is hitting on. If ARC needs trimming on this fan, then I reckon any FMIC would.... bugger! Oh well, there goes my thought that maybe I could get rid of the Blitz and try an ARC :D
The R33 fan is *totally* different to the R34 fan. The R34 fan the middle part has a plug and sticks *way* out from the housing - like maybe a good inch out. That's what the FMIC I'm trying to fit is hitting on. If ARC needs trimming on this fan, then I reckon any FMIC would.... bugger! Oh well, there goes my thought that maybe I could get rid of the Blitz and try an ARC :)
Like I said mate, throw me an offer. Get it while its hot!!!
It took me 2 days at first because I didn't have all the tools, First time I worked on a car and it took some time to find all the nuts and bolts. But it only took me 3 hours to remove the FMIC.
i got a blitz on my R34. didnt have any problems with it clearing the fan. although it is very close.
edit... when you got the kit there should have been 2 brackets for the top of the cooler one for r33 and one for r34
Edited by wasnt me
Did you trim your reo tho?
I've seen a few pics of r33 and r34 now - and their fans seems to be nothing like mine; The motor on my fan sits heaps further out ..
WASNT ME
Reply: I am not sure whether the 33s and 34s have the same principles and I don't doubt you if the blitz doesn't require you trimming anything. ARCs usually have thicker cores isn't it??? As for this particular one that I got, all the brackets are welded to the FMIC. So I am not sure whether it is able to fit a 34
Reply: I did trim my reo alittle bit too. Not much, just nip it where the FMIC meets, angle grinder it about 5 mils, and whack the hell out of it to bend that bit of reo. If you ever take the FMIC out like me, just whack that bit back to its original position.
As to your fan, it sounds like an aftermarket type fan?
Again guys, throw me an offer...... I was real happy with it, nothing wrong with this particular one, just want to sell it as I will not be upgrading my car any more.
Edited by k3vv
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
