Hey Guys ,
I am located in tullamarine Melbourne. I recently wrote of my Black R34 2001 GTT Series II and I was not insured so im therefore stripping the car for parts to get whatever I can back. At the moment only a few parts in the car have been stripped (shown in the list below) . The damage is pretty bad as you can see from the pics but the engine seems to be undamaged and the whole back end is also in perfect condition. There is a range of parts still on the car , Im not to good with the mechanical stuff so if you come strip it yourself Ill do things cheaper. I'm also open to an offer for someone to come take whatever is left of the car which includes the turbo, engine + a range of other mechanical parts, rear brakes (front are sold) , suspension, windscreens etc. Open to any reasonable offer keeping in mind the 2001 model is very rare and the car was very clean , I was only driver in Australia and only drove it for about 6 months (engine done 120,000km). rare I will also post interstate via cash on delivery or courier if needed. CALL OR TEXT ME ANYTIME ON 0423809544 FOR ANY QUOTES QUESTIONS PRICES OFFERS ETC ..
Some pics of the car as a whole:
post-75291-1280233115_thumb.jpg TURBO
The parts for sale that are off the car and ready to sell are:
1. Rear bar - excellent condition - $400
2. Rear lights - $400
3. Front Pair of Xenon lights - $500 SOLD
4. Stock intercooler + piping and box - $100 SOLD
5. Front bar with reo and foghlights - (small dint) - $450
6. Complete drivers side door with mirror power windows and all - excellent cond just needs a good wipe- $500
7. Complete boot (with trims) + spoiler - $500 (also sell separate boot $300 spoiler $200)
8. Front headrests - $80
9. Cd Stacker $70 (also have a pioneer japanese dvd navigation unit that came in the car from japan for sale)
Edited by khuss88
hopefully u came out of that alright looks pretty bad =S and hopefully ya had no passengers
Unbelievably he had a passenger & they both walked away with only a little bruising!
I went in & picked up the front brakes the other day, seller was a top guy, really helpful.
front seats are wrecked back ones are fine
steering wheel seems fine but buyer has to come remove themself
wheels are sold
car was auto not manual
i got the ashtray pm sent
anyone need nethn else ??
cheers guys
hi mate... still got the stock steering wheel with airbag? did the air bag go off?
let me know
cheers mate
Yeh i do , its still on the car , got no idea how to take it off and no the airbag didnt go off
the wheel spins fine so pretty sure its still usable , heres a pic :
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
