Does anyone have any force velocity graphs of dampers installed on their Skylines?
I am trying to work out what damper rates would be suitable for a spring change & am having trouble getting any decent information out of the suppliers. If you could make mention of the spring rates they go with that would be great.
https://www.sau.com.au/forums/topic/330935-damper-graphs-wanted/
Good luck with that. Really, the only way you're going to get that info is if you have a friend with a shock dyno and can convince a bunch of people with the same car as you but also with all different types of shocks for you to remove from their cars and test on the shock dyno. Not likely.
Why do you feel you need to be so scientifically specific when it comes to shocks, there's a bunch of excellent options straight off the shelf that any suspension shop worth their salt should be able to match up to suitable springs for you.
I am manager at City Suspension in Brisbane and can discuss it with you if you want to give me a call at the office during the week, 3808 3266 ask for Tim.
Edited by BI6TIM
The point is that once you have calculated the damper rate for bump & rebound and worked out the acceptable range on what you want for both ends of the car it would be nice to be able to tell by a means other than the usual salesman blandishments that the shocks are, infact, what you are after.
The information is not unknown or even unavailable. It is not a case of being so scientific, simply a case of being able to select a shock using some basic information.
The suspension shops match springs to cars & to dampers. But htey do so in such a broad range that makes me less than 100% comfortable with the selection.
Anyway, love to all, etc. :)
I'm in the same boat, post any findings you get djr.
As much info I have at the moment is as follows. The numbers are based on the sprung weight of my car & hence will be different for others, obviously.
Stock R32 GTR info:
Front spring rate 2.4kg/mm & damper rate based on 0.3m/sec - assumed to be linear
Front bump damping ratio 0.25 (500N)
Front rebound damping ratio 0.89 (1746N)
Rear spring rate 2.7kg/mm & damper rate based on 0.3m/sec - assumed to be linear
Front bump damping ratio 0.24 (402N)
Front rebound damping ratio 0.66 (1108N)
Nismo R32 GTR info:
S tune damper set to the middle of 5 settings.
Front spring rate 5.5kg/mm & damper rate based on 0.3m/sec - assumed to be linear
Front bump damping ratio 0.36 (1079N)
Front rebound damping ratio 0.64 (1912N)
Rear spring rate 4.5kg/mm & damper rate based on 0.3m/sec - assumed to be linear
Front bump damping ratio 0.32 (686N)
Front rebound damping ratio 0.63 (1373)
Notes:
A reduction in srpung weight gives you an increase in damper ratio.
An increase in spring rate gives you a lower damper ratio.
What is deemed acceptable for bump & rebound ratios for the front & the rear is arguable. I am presently chasing some info from some of the damper manufacturers but who knows if they will come good.
try calling suspension technology australia in yass, nsw. for the reasons you're stating i had jap ohlins, bilstein pss9, sydneykid bilsteins, and konis both original and revalved dynoed there. john also had graphs of teins that from memory came off a 32 gtr. he's a font of knowledge and very good with this stuff. he used to work for eibach and has been in the game for donkey's. did brock's targa monaro suspension too. unfortunately i don't have the graphs anymore but he could prob be persuaded to part with the info.
good on you for going down this path, too. i've found once you decide to ask the really hard questions about what you're spending money on, and decide to do some research to get to the real truth with these things, the information dries up unless you persevere and get it yourself but it's worth it.
Edited by Scooby
Yes cheers. The have some good systems. I think (from memory) that getting them to go through the sheets for your car was well priced & that getting the dampers dynoed was equally good value. Just out of interest did you get them to produce a set of sheets for your car?
As for the second paragraph that is exactly what frustrates me in trying to modify a car. I don't reckon the questions are actually very hard but it doesn't mean they get answered.
lol your are spot on there djr. the questions are really basic, no-brainers even, but it's frustrating when no one knows the answers to the fundamentals and even more frustrating to think that people in the industry haven't bothered to find out. try getting empirical evidence on the often quoted RB30 harmonics issue or the benefit of dump pipes. i can't really blame the industry though, research does cost and if people are prepared to part with their money...
you prob know this but if you want to see whether a susp guy is thinking, ask what sort of bumpstops they use and why they chose that elasticity. if they use the term 'universal' ask how they can use the same units on a GTR as on a Civic. that's the thing with john, he has prob 20 different types because he understands the importance and with limited travel the 32 needs some thought in that area.
STA did produce graphs for the dyno, if that's what you mean. can't remember the cost but it was well worth the $ to know, particularly when i found that one set with 36 click adj only worked from click 25 onwards. imagine the stuffing around that saved in terms of trial and error.
Edited by Scooby
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
