hey all,
i just ordered a full set of cst hyper zero 1 in 18x9.5 +15...
i have a r32 gtst..
wondering, what size guards i would need 30mm, 40mm, 50mm..
also
still undecided,
what tire?
215/40/18 front and 235/40/18 rear?
car is gonna be tracked (grip) and ppl have said the tire could pop off the rims with those sizes on the front?!
what do people think?
https://www.sau.com.au/forums/topic/331230-rims-and-tyres/
so you want the kool look of a drift car but the functionality of a grip car aint guna happen, 215/40 wont pop off, id go with a 215/45 though. with a 255/265 youd probably be looking at running at least 20mm overfenders.
check post #138
http://forums.gtrcanada.com/gts-discussion...-thread-14.html
https://www.sau.com.au/forums/topic/331230-rims-and-tyres/#findComment-5378295
5mm is a lot of difference when choosing tyres for guard clearance.
i used to own a set of cst's, dont have the pics on this comp if i remember when im on the other comp ill post em, they were 17x9.5 +15 and i ran federal SS595 215/45 all round, the rears fit with the lip rolled, the fronts were a little mexican definately needed a roll/flare or try 215/40 and a little camber.
https://www.sau.com.au/forums/topic/331230-rims-and-tyres/#findComment-5378405
still undecided on this!
i wanna run a 235 allround (federal 595ss)
if i run 3 deg camber on the front and get as close to 0 on the rear will they fit?
otherwise a 215 on the front and a 235 on the rear..
more camber on the front is gonna help with grip anyway!
hmm..
i have had a 18x9 +15 on the front with a 235/40 that didnt stretch.. and they fit fine.
and also a 18x10 +22 on the rear with a 235 and they were fine..
so should fit with a 235 on the front with 3deg camber..
https://www.sau.com.au/forums/topic/331230-rims-and-tyres/#findComment-5401838
im not telling im stating what i have done in the past, and a 9.5 +15 is still a fair whack more to fit under a guard than a 9 +15.
its more to gather info on what others have run, and see if anyone has run these setups on the odd occasion on the track..
in no means telling anyone what to do!
https://www.sau.com.au/forums/topic/331230-rims-and-tyres/#findComment-5401867
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
