Caltex on Sydney road also has a E85 pump, just a heads up to the north siders.
Yeh man, been using that one for years, local to Edge too which is good as you chug through the ethanol on the dyno.
  • Replies 68
Exactly lol. Btw ive sent you a friends request, accept nigga !
    • Well, this, but braided line to the sender that is mounted on the chassis. Oil Pressure doesn't need to be close, while I prefer Oil Temp is in the active oil flow (bro science, not sure how much it matters).  That's how I've had mine set up for years and it works OK
    • Welcome back! There is a v series forum, a little quiet at times but every new active member helps
    • But, per MBS206's question, what happens when it doesn't start. When you turn the key to IGN, do the dash lights come on (then go off after a couple of seconds) - likely alarm or other electrical issue When you turn the key to STRT do you head a clear click (the starter solenoid trying) without the engine turning (likely starter motor)
