21AZI
Suspension: S13 Front Hubs, S13 Fully Adjustable coilovers all round'
R32 GTR 4pot Front Calipers and GTR rear calipers, 5 std, Front Sway Bar & rear,HICAS removal
Wheels: Front 18x8 with 225/40/18 tyres and Rear 18x9.5 with 285/35/18 tyres
The engine is a R34 RB25 neo.
Modifications: Gearbox 5 speed GTR R32, Chrome-moly flywheel, Brass button clutch, Bosch 040 fuel pump , surge tank, adjustable fuel regulator , Catch can , Apex bov,15" Davies Craig thermo fan, VL Radiator, Turbosmart boost controller, Battery in the boot, front mount intercooler, plenum and 68mm XF body,1 piece tailshaft, hks cam gears,Oil cooler and oil filter relocation, micro tech LT-12, TO4 Turbo 69hks inlet wheel and 0.7 housing exhaust , Tial wast gate, 10l sump (for Oil), head std kit (ARP), mean std kit(ARP), com head gasket, gates timing balt, N1 oil pump and lots more.
Stereo Audio / Visual: it works and T.V
Estimated Power:1st dyno it made 298hp on 7-8psi and then on 12psi the new GTR clutch late go at 5500-6000rpm and it still made 347hp it was back in the year 2001.
Lates Dyno was it Pits on the 10/9/2009
And it still made 270hp on 7psi
310hp on 12psi
350hp on 15psi
And that was the old sit up
Here are some photos of the new R33 diff in my HR31
RB26/30dett Engine Build
Just a little list of parts in the RB26/30DETT
Conrods (Howard)
Pistons(CP)
Oil Pump (Greddy)
Oil Pump Drive Extension
Cam Gears (Greddy)
Camshaft (Tomei)
Spring (Tomei)
Lifters(Tomei)
Retainers(Tomei)
Head studs (Tomei)
Main Studs (ARP)
2mm Valves Inlet & Ex
Ross Balancer
11L Sump
2x GT 35/40
And more
990cc
We see how it go's
https://www.sau.com.au/forums/topic/332032-21azi-shtbox/
  • 1 month later...
Sorry for the shite photo's, It was a loan phone
R33 GTR engine cradle and R33 diff cradle are in my hr31 now. HELL YER
The holes are cut for the front axle's for the AWD.
Just waiting on the RB26/30 to be fitted agian then off the get it painted.
https://www.sau.com.au/forums/topic/332032-21azi-shtbox/#findComment-5457419
  • 5 weeks later...
LOL
If you think the hr31 is get built fast, you should see my rodeo!
The awd drive is all done now on my hr31.
Got a hold up on the hr31 now. as i need to finish off my rodeo first (Who what to buy a cool show Rodeo?)
Cool
(fats)How far off is your HR31 from awd?
Did you put the r32 rear diff in as will?.
On the front rails, did you cut it back about a 100mm for the gtr cradle and did you use a r33 or a r32 cradle?
You got same photo's
love to see how you did it
https://www.sau.com.au/forums/topic/332032-21azi-shtbox/#findComment-5523984
nice work
just sticking my gtr front cradle in my hr31
any more picks
things you would have done diffrently?
and thats a hell of alot of turbos for 800hp
i love it!
Got same more pics
Just have to her to post them up for me.
Done diffrently
I should have done it all 10years ago when I built the car the first time.(Before I boke my Back)
It's hard to whiching people working on your car.(But Jeff is a f**ken Good Guy).
"Hell of alot of turbos for 800hp"
LOL that's on low boost
Who what to buy my injectors They are 990cc. I need to buy same ID2000
Edited by 21AZI
https://www.sau.com.au/forums/topic/332032-21azi-shtbox/#findComment-5524604
  • 1 month later...
  • 3 months later...
  • 7 months later...
    • It seems to happen only when moving not stationary. It happens more frequently when reversing and turning steering wheel to the right. I MAY have found what the sound is and if it’s that I will feel so dumb since it did start happening around when I put 18” wheels. I attached the image of where there’s a scraping line to that plastic liner and the other side does not have that.
    • Is it a noise that if you turn the wheel, and hold it turned to the right, the screech continues? Or does it only occur while you're moving the steering wheel? Does it occur when stationary turning the steering wheel from centre to the right?
    • I want to also note I did lift the tire and checked for any play to see if it was a bad tie rod. It doesn't move at all.
    • Any insight will help find the issue. When I do a sharp turn to the right I hear a screeching sound coming from the front. It only happens turning Right and not Left. Steering fluid seems okay. Not sure what this part is(picture) but one side seemed "wetter" than the other. All bushing from a quick look did not seem damaged. I'll do a better look but wanted to ask here in case it helps me troubleshoot faster.
    • Nah, they'll do it without a receipt, tell em roughly when it was, that it was cash, youll likely only get store credit, but that gets you some dollars towards the newer better shovel, or other item you need/want later.   Still take it back and have a crack at returning it.
