Up for sale is my series 1.5 1994 R33 NA Skyline, white
car has just hit 180,000k's clean car great for a p-plater.
It has never been thrashed I'm only a 3rd year apprentice so can't afford to wreck it and pay for it.
The car comes with the original rear and front bumper bar and original nissan rims with tyres unless unwanted
Mods
Drift pod filter
2.5inch catback exhaust with sports muffler gives are nice deep sound
New rockercover gasket
Struts with tein springs all round
Adjustable rear upper camber arms
Body and Wheels
400r bodykit with tommy kaira front bar
Brand new tyres on black koya 18" inch rims
Stereo
JVC headunit with ipod and aux inputs
Fusion splits in the front
Fusion reactor 6X9 3 ways in the rear run off a fusion 350watt amp
Fusion reactor 12inch 600 watt sub run off a fusion 450watt reactor amp
Bad Points
Only bad points are the boot fit out i did i havn't had time to fit the carpet but can do that on sale,
and the thrust/release bearing makes a slight noise sometimes when the car is cold once it's warm it stops
other then that the car is mechanically sound and never had a problem with it
Rego until november 2010
RWC will be supplied on deposit
Asking $10,000 cash price is negotiable prefer cash but willing to swap for a 180SX or something of interest turbo is ok
Located in Brisbane/Gold Coast
Interested buyers only please no time wasters
https://www.sau.com.au/forums/topic/332066-r33-skyline/
  • 1 year later...
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
