Hi guys, i have a few bits and pieces for sale from a project that didn't go ahead.
Item 1. Garrett GT35R, 0.82 rear housing. It was supplied by GCG turbos, and has done a few thousand k's, and is in great condition.
Item 2. Exedy Hyper Single. Push type, suits RB20, RB25, and early RB26 motors/boxes. BRAND NEW.
Item 3. Recaro SR3 seat. Includes seat rail to suit R32/R33's.
Item 1. $1200
Item 2. $850
Item 3. $450
Located in brisbane, QLD
Contact me here, or 0423 766 972. I am happy to post anything (at your cost) .. the seat i would prefer pickup only, just cause it's hard to post.
Yes i have another of the rear - it's an external housing
And the yellowy/white stuff on the manifold flange is some leftover masking tape - i have kept the turbo sealed up to stop any dust/debris getting in it :)
  • 3 weeks later...
