Rb25+ Gearbox+diff $1900 Ono Also 4x R34 Rims $200
Hi there, up for sale is the remains of my car one owner car for 8 yrs all serviced with synthetic Oil.
Engine in great condition has split dump and adjustable exhaust cam gear, last dyno was 211rkw, also 5 speed has organic Clutch and high pressure cover
diff is standard 4.11 would like to sell all in one lot. R34 rims in good condition with wheel nut covers.
Call anytime after 8am on 0429 607 597 or PM me here
