Guys my car has had a misfire prob for a while now... but only used to happen on a frosty morning and the prob was gone not long after,
yesterday whilst talking about how the problem had vanished (Jynxd hard) the problem re occurred while the car was idling the car at the time was at normal running temp and had been driven most of the day (just cruzing) now the missfire is im 95% sure is coming from all 6 cyl
Things to know
Sparkplugs new
Coilpacks new
Sparks have been pulled out while problem was occurring (while engine off for smart asses) and found no moisture at all plugs are fine.
has been hooked up to ultrascann and no error codes were found car has not stopped misfiring since last night and i dont think it will...
What is my next approach ?
I have 1 idea... but not sure... im assuming the Ignition moduel may be shot... can ne1 with an rb20 moduel please let me borrow it for 5 mins ? as i test to see if its the problem ?
Thanks guys ..
https://www.sau.com.au/forums/topic/332113-rb20-missfire/
Things to know
Sparkplugs new
Coilpacks new
Thanks guys ..
Im 90% sure it would be your igniter. My rb20 did the same thing, it was really hard to start, but shortly after, the car didnt start at all and the first thing i replaced was the igniter. ran perfectly after.
https://www.sau.com.au/forums/topic/332113-rb20-missfire/#findComment-5388248
You should also consider a faulty injector, given all the plugs were dry when you pulled them out. If it was spark, there would have been 1 wet plug. Check all the injector connectors for white/green corrosion :verymad:
Thanks
Rob
https://www.sau.com.au/forums/topic/332113-rb20-missfire/#findComment-5388257
Thanks
Rob
true that, Possibly even send them in to get cleaned if you have the time.
https://www.sau.com.au/forums/topic/332113-rb20-missfire/#findComment-5388262
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
