Hey everyone, I picked this up the day before yesterday for a trade of my XF ute and a bushbasher XF with a good engine and a 5 speed. My mate that traded it to me had no need/want for it and was green with envy as another one of our mates just bought an XH ute with a few mods that has 199.1 HP at the treads and now he's in pursuit of a fun ute aswell.
It's a 98 model VT (if you don't like the fact it's not a skyline, don't post please)
Good points:
GETRAG 5 speed manual from factory
Good paint
17's
New tires
Everything is in good condition, no bumps/rattles etc (it's rattle less than my AU)
Bad points:
The GETRAG needs to be recoe'd/replaced
Apparently the springs in the back are worn and make it unstable at speeds of 140kmh + (I've had it to 140 and didn't feel anything untoward, private road ofcourse) so is this an honest reason to make a car unstable? It really seems to handle quite well and I couldn't fault it, but maybe I was just lucky.
The getrag makes horrid crunching/spinning noises going into second and all the other gears if you get up it, you can make no noise in any of the gears if you drive like an absolute grandmother. Because I have no idea wtf is wrong with it, I won't be driving it until it's fixed.
My plans are to fix/replace the GETRAG, lower it, put a stereo in it (the old one was taken out), give it a good clean as it's filthy, and sell it to buy something else, VT's aren't my favourite car.
Here are some pics:
So once the gearbox is fixed, I am confident that there is absolutely nothing wrong with the car, it starts first go, has 212xxx km, handles great and has a 5speed. How much do you guys think I could fetch for it? It really is in great condition apart from the gearbox.
OH and it has a new clutch :verymad: I think I got a good deal.
https://www.sau.com.au/forums/topic/332146-new-car/
Back to boostcruising please..
I think you should head over to booscruising, considering you can't punctuate your post with a comma. I don't like commodores, this is just a way for me to make some money to go toward a skyline, I have no intentions of keeping it.
https://www.sau.com.au/forums/topic/332146-new-car/#findComment-5388192
Maybe $4000-$6000? Being a manual is a bit rarer since most VT Executives are autos.
Just look through carsales prices I guess.
Thanks mate, I was thinking the same. Definitely an easy dollar, considering I was going to try and get rid of the ute's for $900.
https://www.sau.com.au/forums/topic/332146-new-car/#findComment-5388196
If it is in good condition and you get the manual all sorted I don't see why you couldn't sell it for $4000. Like I said, look on carsales for a similar condition/spec car and see what people are asking. Then maybe put it up for sale for a bit cheaper than every one else for a quick sale.
https://www.sau.com.au/forums/topic/332146-new-car/#findComment-5388220
Definately be able to sell it, as P platers would love it, being a manual!
Yeah mate, that's my target market :verymad:
Cheers man. I'm gunna clean her up next weekend after I get the box out, probably gunna change the trims between the front and rear doors on the outside of the car as they are faded, put a stereo in it and replace a hazard light button that it's missing and put it up for $5,000 and see what people will say. Carsales has some decent examples for between 5 and 7k, so I think I'll make a killing, considering it cost me pittance.
https://www.sau.com.au/forums/topic/332146-new-car/#findComment-5388233
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
