1990 r32 gtr ... for sale ... rb30 block rb26 head. twin turbo ( r32 n1 turbos ) coilover suspension ,apexi pod filters . 6 months rego ,sellin car as is ! $22.000 obo call dion on 0430030051 if i miss your call txt me ...cheers
Edited by oooGODZILLAooo
https://www.sau.com.au/forums/topic/332271-for-sale-1990-r32-gtr/
better info on the whole car (all mods), engine bay photo and interior photo please.
hi richy ,ill post some more pics up tomorrow of the interior and engine bay. interior is in good condition , no holes in carpet or seats ,tho there are 2 bubbles under the vinyl on the dash board, i have a replacment dash board included with the car upon sale. engine bay is pretty well stock only visual work done to the motor is twin apexi pod filters (not boxed) . and (rb30 os giken block ) $27.000 i am told its worth ...unsure on any internal work that has been done to motor as rb30 conversion was carryed out in japan ... and not by some bogan ... there is no BLING BLING under the bonnet ...
hey mate im interested but how negoatiable on price are you?
hi macostar ,you can make me an offer and we can go from there ,price is pretty negoatiable... contact me on 0430030051 to discuss price as
i have my r32 listed on ebay ,auction ends in 5 days ... cheers
What proof can you provide to validate the OS Giken bottom end?
Is it an OS RB30 or RB315?
Can you provide a full list of modifications?
OS Giken does not make 'blocks', they sell complete assembled bottom ends built to withstand up to 1400HP, which consist of an RB26 block, OS Giken spacer plate and liners, OS Giken forged crank, rods, pistons and more.
Take some photos of the engine and the spacer plate between the block and the head should be very obvious, this will substansiate if the car is actually running an 'OS Giken RB30' or just a run of the mill RB30, or something else again.
Thanks.
Edited by R33
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
