Hey guys, had my forged rb30det running nicely for 5000kms or so afterwhich the internal gears of the oil pump decided to let go.
Unsure how long the engine was left running on the dyno with no pressure. The drained the oil had no chunks just a really fine silvery shine throug it, which is a worry considering the oil was changed the night before the dyno. I pulled the oil pump out and found quite a few small chunks of metal through the pump and on their way towards the oil filter.
What sort of damage do i have to look for to inspect the head??
I am planning to pull the sump off and replace the bearings and crank, pull the head off and completely dissemble that and give that a clean, as well as clean the block as best as i can. My main question is if its definately advisable to completely strip the engine and send it off to have a bath, i was planning to just run thru a few containers of shit oil at idle to clean it out, assuming the oil filter would remove any bits of metal?
I have been talking to a few people, who seem to think the engine was improperly balanced first time around, as my machine shop balanced the crank by taking weight of the flywheel and balancer. The balancer also had a bit of play on it on the crank which most likely contributed to the oil pump failure, not that spending most of its time redlined helped. So im getting the new crank balanced elsewhere with the new ross balancer and old flywheel. The pistons and rods are what im most confused about, the rods were measured to be within 1.5 grams of each other and the pistons were within a gram of each other. I was told that that was fine and the shop didnt balance them up, im now being told that for 8000rpms on a rb30 that this most likely needs improvement? Is there really much to be gained by completely dissembling them and getting them rebalanced?
Also if the pistons and rods are pulled out.. assuming the rings and bores are still in good condition, can they be re-installed without getting new rings and re-honing the block?? I'm not trying to be cheap, just trying to spend my limited time and money on where its needed most =P
Also trying to correct my excess oil to the head problem while the engine is apart, if you wanted to run a crankcase vent from the sump, where is the best place to connect the hose? im guessing it has to be above the level of the oil otherwise the air wouldnt travel up the hose?
Kind Regards
Jarrod
https://www.sau.com.au/forums/topic/332272-need-advice-after-oil-pump-failure/
blocks need to be properly cleaned, all oil gallery plugs need to be removed and brushed through. Oil restrictors need drilling out too and this is something that is rarely done. I watched my own engine block be cleaned, it took a total of 3 hours work before it was satisfactory.
45% of rebuilt engines prematurely fail due to contamination from a 'dirty' build. Clean it properly, keep it clean and your 1/2 way there to a sucessfull rebuild.
Edited by blitzxtr
what revs was done? also the rev limmiter will have a big efect on a oil pump failure.
this topic is a massive can of worms.
at a minimum you need FULL WEIGHT FLYWHEEL, ROSS OR ATI CRANK DAMPER, FULL FACE CRANK COLLAR AND A N1 OR BETTER OIL PUMP.+ a rotating assembly balance. within 1 gram is ok. bettter if posible.
if you have all of these things and it let go then there is a big problem.
the revv limiter was 7250-7300 with a power fc pro ignition cut type rev limiter..
At the time i had a series 2 r33 oil pump and standard rb25 harmonic balancer, i had a bit of troubles with the balancer with the keyway being a little flogged out.
Planning to get a new crank and balance it somewhere else, a Ross drift harmonic balancer and a nitto oil pump, going the pull the engine apart and get the pistons and rods balanced to a higher degree as well, should make it a lot stronger.
Also planning to get some drop in cams and springs this time while its apart.. anyone got any preference between tomei poncams 256s and the 256/264 HKS setup with adjustable cam gears.
Jarrod
totally agree Paul.
Jarrod, did they replace the water/oil heat exchanger at the oil filter and any oil coolers? Never re-use them after an engine dies.
In any case, this is a warranty issue right? something was clearly wrong in the maching or assembly. Hopefully you paid one shop for both so there is no fniger pointing about the failure.
New crank is a good idea, especially if the keyway was average in the first place, the old one would probably need undersize bearings too after
BTW don't worry too much about how long it ran without oil pressure. If the light comes on at high revs its already too late. Also, the oil pump failure is often the symptom, not the cause, the gears crack when they try and push metal through.
My first engine was the standard rb25, but it didnt break.. i tried relentlessly at 27 psi but gave up in the end, i built the rb30 myself but had all the machining done at a local machine shop. I'm not out to point fingers and blame anyone that helped me as its more than likely my fault.. which is part of the "fun" when your learning everything yourself from scratch.. i got a few big burnouts out of it.. so im glad i got that much :)
I've pretty much bit the bullet and decided to send the bottom end over east to get inspected to see what they think went wrong and to make sure it doesnt happen again, and to balance it properly this time and adapt some rb26 bearings for it.
So dont reuse the standard rb25 oil/water cooler?? i was thinking about buying a oil cooler anyway so i might just add it to the list.
Cheers for the input
Jarrod
And the pump didnt die on the dyno.. it was getting tuned on the dyno, but sending the knock sensors crazy, not being happy with it he took it off the dyno and was driving it back to the workshop.. and said on the way back it started to flicker around a bit then dropped to 0 as he got into the street, so it possibly got driven a little bit, i might chek the oil from my last couple of changes and the filters to see if they have any bits of metal in them.
Jarrod
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
