Hey guys
Item:
5 Speed manual gearbox, came out of my r32 GTS-T rb20det 2 door
Genuine K's: 86,000K's
Excellent condition!
Price: WAS $800 NOW $400ono
Can Frieght at your expense
Item:
Set of 4 rims with brand new tyres, 1 tyre needs to be replaced. All 4 caps are there. They are 4 or 5 stud wheels.
17x7 Sparco Wheels
Rears 235/45 ZR 17
Fronts 215/45 R 17
Price: WAS $800 NOW $600ono
Item:
Mint condition drivers side skirt for 2 door $80
Item:
Mint condition manual tail shaft for 2 door $140 or take it with the gearbox for $500
Item:
R32 GTS-t Front rotors and 4 pot callipers
Genuine 86,000K's
Excellent condition
Price: WAS $400 NOW $250ono
Item:
R32 GTS-t RB20det
Factory Dump Pipe to Cat, 2 piece.
Excellent condition
Price: WAS $200 NOW $170ono
All prices are neg. Make an offer on all parts. Can also frieght any parts at your expense
If there is any parts you need from an Imported 1994 R32 GTS-t 2 Door Coupe Message me and see if I have it!
Located: Victoria
Contact details:
PM Me
[email protected]
Txt only 0448 644 653
Pics:
https://www.sau.com.au/forums/topic/332422-parts-for-sale/
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
