hey skyline lovers,
purchased a drift electronic rpm gauge just trying to find my tach signal i have flush mounted my gauge and now trying to find the tach signal from my coil ive unscrewed the allen key bolts on top of the head and am now stuck with the signal wire and finding my leading coil
can anyone please shed some light on this or will i have to wire it up to my ecu somehow
this is a head case and a half i really am starting to get pissed off haha,
tryed attaching my tach signal on my digital rpm gauge to the yellow wire with the blue stripe after i stripped it behind the dials, also tryed the yellow and the green striped wire and just connected the + and the - to a battery that i got lying around, started the car and no luck...
the guy at autobahn said i have to connect it to my leading coil im in a real pickle at the moment my whole dash is apart and from 7p.m-2a.m ive been trying to sort this motherf*%$#r out and it wont work... will i need to connect it closer to my ecu or have i got the wrong wires completely? :):)
Whats wrong with the awesome tacho next to the speedo that came form factory??? Get a shift light, preferrably one of the pencil types that don't stick out like dogs balls and then you'll be set...
hey,
the rpm gauge that i currently have is flush mounted in my old cluster it has a inbuilt shift light about the diameter of a pencil if not smaller i believe this one looks 10x better i was just wondering if anyone could help with the wiring and how to connect this electronic rpm gauge to which signal wire if not wires
cheers chris
had it connected to pin 7 (yellow with blue stripe wire) behind the cluster and temp to a + and - on a battery i got lying around and no rpm reading
will it have to be conencted closer to my ecu for a rpm reading?
thankyou for everyones time chris
found a interesting thread that makes me think i have the wrong signal wire could it be pin 7? which i allready have tryed behind the dash cluster or could it be pin 53 "which is the Vehicle Speed Sensor signal is basically engine rpm's"i have read to connect it closer to my ecu for a reading but i would have thought if i have the yellow and blue striped wire (pin 7) behind my cluster i should get a reading the gauge is electronic/digital if that makes a difference?
here is the thread anyways http://www.skylinesaustralia.com/forums/Rp...ed#entry4042455
was reading over a thread a while ago and im not sure but dose anybody think i might have to attach a resistor and a tacho booster i have no signal from pin 7 which i connected behind the dash cluster which is the yellow with blue striped wire i will re-connect it tomorrow to pin 7 from my ecu
any ideas/thoughts much appreciated chris
its a multi cylinder gauge can be switched once the power is fed to it with a click of a button...
went out today and purchased a signal booster for my ecu for $160 as i was told that is my problem as the current coming from the ecu is only 5-7v and the tacho is 12v when i power it to a battery it lights up/illuminates but when the signal wire is connected to pin 7 no rpm reading once the car is running and the gauge is set for 6cl mode
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
