Hey guys i am pretty new to owning a skyline YAY and it came some 17inch volk se37's came on the car they came with it when it was imported and i was reading through a magazine and i found the rim's on a the bozz-speed evo and it said that they were discontinued and some of the lightest wheels the company ever produced. so i was just wondering how much they would be worth? They are in good condition with a very little it of gutter scratch on two of the 4 wheels but other then that they're perfect ive added a picture to show you the type im talking about. I posted this in the totally wrong section sorry for the double post.
https://www.sau.com.au/forums/topic/332512-pricing-on-volk-se37s/
Hello Mate
what colour are they? (pic didn't work sorry)
Do you know the widths and offsets?
The SE37 is a great looking rim and is a forged monoblock rim, just like the TE37, CE28n etc - so yes is very lightweight and strong. I've found it to be one of those rims that people either love, or don't rate at all. Price wise, can't really say without having the info above though :woot:
Cheers
Aaron
Ahh sorry man im new to the forum so im a little bit sketchy on how to use it lol but yeah this pic should work they have 235/45/17 on them so maybe you might be able to work out width or somthing from that but they are super light.
cool, well they're Bronze in colour which is the most popular - so that helps. There will be a blue and white sticker on the inside of the rim which will have the width and offset listed. Will say something like
17 x 8 ET35
PCD 5 x 114.3
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
