Hi KBNR32, i have blue powdercoated RB26 rocker covers / coil pack cover that are unscratched. I was going to get them re-powdercoated black but maybe we can help each other out here. I would be prepared to swap for yours if they are still in the original black. I am also in Melb and can perform the swap if you want. Let me know.
the only thing that i have seen(because i had a set) was the factory jgtcc ones they looked a bit ordinary still so i am working on some carbonfibre ones......i may sell them when finished...but they will be expensive
ylwgtr2.....are you interested in doing a carbon fibre boot lid for R33 4 door???
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
