R32 Gts-t.
i've just been bench-testing my coils, and in particular checking output voltages. does anyone know what the voltage should be? and whether it should stay consistent throughout the rev range?
at idle they seem to sitting around 28,000 volts and as rpm climbs up around midrange, voltage drops down to around 10,000 volts, then most the coils were back up to ~15,000 V by top end (the driver i have for them only outputs up to approx 5500-6000rpm) so beyond that rpm i haven't been able to test.
ideally i'd like to hear from someone who's tested brand new coils and compare results. i'm not optimistic about my coils, they are old so not expecting great things from them. if new coils maintain a consistent voltage throughout the rev range then im putting new coils on the shopping list.
https://www.sau.com.au/forums/topic/333110-coil-output-voltage/
this is how the readout went, the volume and pitch of the spark noise goes up and down with the firing rate. basically just started at idle, went to top, then back down to idle. so you get an idea how the voltage changed.
  • 1 month later...
the only info on the splitfire coils i could find is for the sr20det
here is the link to their page with the info:
http://www.splitfire.com/splitv_disystem_nissan.html
So according to graph 2 i think they are saying that the normal/stock sr20det coils output a stable 20 millijoules up to 8000 rpm, whereas the splitfires output around 30 millijoules.
I also found some info on the ls coils, but he has only measured the peak secondary current and of course is in a different unit of measurement:
"On the LS1 coil there is around 40 milliamps of peak secondary current with 5 milliseconds of dwell time. On the LS2/truck coil (AC Delco D585), there is 120 milliamps!"
this info is from:
http://www.megamanual.com/seq/coils.htm
Maybe some people better versed in electronics can help us out...
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
