Hi guys,
         Need a deposit for a home so I gotta sell a bunch of stuff, I have here brand new in box Tein super streets with tops for R33. Was saving them till I got my new rims but all my toys need to go . Bought them last year for just over $2200. I'm asking $1850 ono.
https://www.sau.com.au/forums/topic/333115-tein-super-street-for-sale-r33/
do you use freight companies? vicfast startrak etc?
I can freight it for you if you like, prob cost bout $35 or so depending where u are, or I could drop it off.
HI, Sleeper7
Sorry for the silly question, will this fit to my 1998 R34 GTT
If YES, I would keen to buy from you
Cheers
Lucas;)
fronts yes but backs are a maybe, depends what type of shock you have at the back. R34 had two models of suspension, but u need to poke you head under the back too see if they are the same as r33
  • 1 month later...
  • 1 year later...
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
