Hi Riceline, in your picture you cut off the 4th connection, the one that goes to the PCV valve on the plenum.  It is on the cam cover juts down from the blue one in your picture.
If you open up the angle of the photo a bit so we can see the inlet plenum, then I can draw on your picture the choices you have for plumbing up a catch can.  Yes that's right you have CHOICES, there is not a wrong and a right. :P
Id be extremely interested in seeing this too, I assume itd be along the same lines for a GTR? Looking at putting one on, what would be the best way of doing it?
  • Replies 64
Exactly the same for a RB26DETT, or an RB20DET or an RB25DET or an RB31DET (in my case). But keep in mind there is no "best way", you choose whichever suites your requirements.
I call the choices :cheers: ;
1. 100% plumb back
2. 50% plumb back
3. Zero% plumb back
Anyway, more when the picture is up. :wave:
So what options do/dont u have if your catch can isnt vented?
I have a trust can which is basically hollow but looks cool.. not vented.. u know the one.
Whats the best option for say; 230rwkw or less, running either standard or hiflowed turbo, big intercooler, on 12psi constantly?
I think this suits alot of people...
Is this right?
Let's try this one, it's the open to atmosphere catch can;
The idea is to only have one connection from the cam covers as they are joined by the standard pipe. The PCV valve and the connection to the inlet before the turbo are blocked off. You can have a return (drain) to the sump form the catch can if you like. Don't T it into the turbo oil return as it is under a bit of pressure and the oil can run up into the catch can.
The other 2 options follow in separate posts. :D
SK doing it that way wont cause any probs to idling?Don't laugh but is the blow-by metered by the air-flow meter,coz after all it is air that has been metered.What i'm trying to get at but slowly :D is blow-by the same as air from a bov that is being vented to the atmoshere?
SK doing it that way wont cause any probs to idling?Don't laugh but is the blow-by metered by the air-flow meter,coz after all it is air that has been metered.What i'm trying to get at but slowly :) is blow-by the same as air from a bov that is being vented to the atmoshere?
Good question R31 POWER, but if your engine has enough blow by to cause idling problems, then it is not the blow by that you should be worried about. :spew:
Sorry for the delay, virus on the laptop :type:
This one I call the 50% plumb back, because half of the time (no boost times) the air from the catch can is being sucked into the inlet manifold via the PCV valve;
It is not my favourite, because you can still get a bit of oily air into the engine, but since it doesn't go in under boost (the PCV valve is closed then) detonation isn't much of an issue. At least you don't get any oil into the intercooler and its pipework.
The last is 100% plumb back, all of the air goes back into the engine. Some goes via the PCV valve, at times of no boost. When there is boost, it goes back via the inlet system, through the turbo, the intercooler and its pipework. :uh-huh:
The idea is the stainless steel wool, helped by the lower velocity in the catch can, catches the oil and removes it from the air before it goes back into the engine. This is the environmentalists favourite :alien: and is the easiest to get engineered.
SK,
How would you plumb it, if emissions were not an issue, as in a 100% race engine. Metohd 1, 2 or 3 ?
On the race cars we run open to atmosphere. We do run 2 pipes to the catch can and remove the joiner (standard) pipe between the cam covers. It's not really necessary on a road or combo car though, the one pipe does the job OK.
Hope that helps :)
So, would it be acceptable to plumb the PCV line to the catch tank, and leave the joiner as is, with the tank vented to atmosphere ?
As long as you block off the unused plumbing and fittings. I gotta ask why though? :confused:
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
