Hi all,
Having problem with my R34 GTT:
Engine goes very rough at low boost levels, for instance at idle speed and when revving without any gear engaged to about 2-3000rpm it “coughs” and seems to have very rough hiccups all the time, if you know what I mean…? At high boost levels it runs like a dream though, no problems at all to rev to the limiter and there’s plenty of power without delay or hesitation.
So, wtf!? What do you reckon?
Stuff on the car: pod filter, fmic and 3” cat-back.
Also, thinking about leaving Sweden to move to Australia with my girlfriend. Do you recommend it?
https://www.sau.com.au/forums/topic/333454-engine-works-well-at-high-boost/
Yes!! :laugh:
Has your car been tuned or is it stock ecu?
Does it happen while cruising/decel or on acceleration?
hehe, ok! That's all I need to hear, you just made me decide to move there :(
Will need to start looking for jobs first. Thinking about Holden, where's the development site situated?
The car runs with stock ECU. It's all stock except HKS pod, FMIC, HKS cat-back and HKS ssqv.
It happens while cruising, anytime the boost is gentle and even. Decel or acceleration works just fine.
:laugh:
hehe, ok! That's all I need to hear, you just made me decide to move there ;)
:laugh:
I've changed a life. My job here is done :(
So when cruising you would be driving on vacuum not boost yes? On boost you would be accelerating. Does it hunt at idle, like rev up and down? And is it more pronounced when the car is warm or is it exactly the same when it's cold? Sort of sounds like it could be a problem my mates R32 had, was effectively a vacuum leak. The air regulator was stuck open, so when the car was cold it ran fine but when it warmed up the air regulator was still open and the car was getting too much air. Ran fine when you were accelerating, but trying to cruise it would just stutter and jump, etc.
Could also be a problem caused by that atmo bov you have.
YES COME TO AUS! Bring MORE swedish girls with you too! (my GF is Estonian, so if we got more or them/Swedes in this country, we'd be happy men)
Could be the stock ECU is gumby, or the AFM is fail....sounds kinda like it might be running excessively rich, but once the airflow climbs up with more boost, it compensates and evens out...
Might be that you're running too cold plugs. What plugs are you running?
list of mods?
Actually don't know. Havn't checked since I bought the car, the plugs were brand new then. Will check tonight or this weekend. Temp grade 6 is standard, right? With my mods which I've already listed above, should I go for 6 or 7?
I've changed a life. My job here is done :P
Yeah, you're right, vacuum not boost, sorry. I find both the technical issues and the language quite hard you see...
The rpm stays quite even at idle, but not as even as it should be I guess. It "huffs and puffs" quite much at idle, and it's no difference between hot or cold engine. Sounds as your friends R32 had the same probs as mine. Will check the air regulator. One question though; where's the air regulator and how do I check it? :ermm:
In what way might the bov be the thief in this drama?
What I've heard before the stock ECU would cope with the mods I've done already (pod filter, fmic, cat-back, ssqv)? Do you have other experiences? If it is what you say, then a new ECU is the only solution I guess..?
How do I check the AFM? Already pulled out the AFM cable when engine at idle and it started to run really bad, almost died. That means the AFM works, at least a little bit? Can I clean the AFM somehow?
Thanks for your feedback! Will have to bring a lot of swedish girls to compensate! :D
Air regulator is located near the plenum, follow the vacuum line that is Tee'd into the hose coming from the AAC valve.
Bov could be the culprit as it is atmospheric, it releases the air into the atmosphere after the AFM, causing the ecu to over inject and run rich. But bov's usually cause problems on decel, so it doesn't sound like this is the cause of your problem...
Hey again,
just realized that the problem is much worse when engine's warm! Does that make it easier to say what's might be wrong?
Thanks
Ok, thanks mate! Will have to check that out then. Just to clearify: Air Regulator is the same thing as AAC valve, right? Or am I reading the service manual wrong?
This Air Regulator, does it have a part number and how much does it cost approximately?
THANKS!
Problem fixed!! :thumbsup:
Vacuum hose cracks (one was completely spilt all the way along the hose!), useless plugs (original modified to 0,5mm!) and crack angle sensor set to 27 degrees!! :D
Air regulator, AFM and ignition coils works just fine.
New spark plugs, rubber hoses and crack angle back to original 15 degrees - it's all fixed and it runs like a dream! :)
Edited by ksx
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
