I'd like to relocate the battery to the boot and my current normal style battery is shagged, is there such thing as a cheap dry cell on the market? All I'm finding is Odyssey's for $300 or so.
I dont have anything separating the cabin from the boot so a dry cell also elminates the need for venting.
https://www.sau.com.au/forums/topic/333603-cheap-dry-cell/
We just chuck out SBS30 batteries at work when their over 2 years old. I've seen you around the forums a bit so if you want one let us know when your down in Melb and you can come and pick one up. There good batteries as long as you don't run them dead.
Same as these
http://www.hrpworld.com/index.cfm?form_pro...;action=product
https://www.sau.com.au/forums/topic/333603-cheap-dry-cell/#findComment-5407659
Same as these
posts to sydney?
https://www.sau.com.au/forums/topic/333603-cheap-dry-cell/#findComment-5407771
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
